Rad Overflow Question
Gary Schulz
Has thanked: 16 times
Post by Gary Schulz »
Does anyone have a picture of how the overflow pipe was run next to the radiator? Was curious where it was attached and if it used a
"P-clip" on one of the shroud screws. Also how far down it goes... I figured it would be best to get this sorted before installing the engine.
Oneball
Has thanked: 10 times
Re: Rad Overflow Question
Post by Oneball »
There’s a clip to attach the pipe to the cowl. ARA951
LarryLebel
Post by LarryLebel »
The raised area near the top and bottom bolts should have a slit for said clip.
LarryLebel
Gary Schulz
OK thanks... I didn't realize this part was still available.
iain1967s
Post by iain1967s »
If you don’t fit the clips, this is what happens when the pipe hits the fan...
(removed from my car, unfortunately. Damage caused by the previous owner just dropping the overflow pipe down the side of the rad, instead of clipping it in position)
Gary Schulz
Can these clips and hose be fit after the engine is in place?
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Fittig the Clips is a bit difficult when the Engine is in because there is not much room...
The lower clip is fiddly, depends what your fingers are like !
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
i just fit an overlong rad overflow pipe and just tuck the lower part of the overflow pipe it in behind the Steering Rack never been a problem & it will drip when needed onto the ground .. will i now get shot for none originality?
floormanager
Has thanked: 24 times
Post by floormanager »
Today, I've fitted a P clip to one of the bottom bolts. Had a clip at the top. Did not know they were available, thought it had broken off! Result!! :D
