silly question - best way to fit carpet studs to the sill?
- Has thanked: 18 times
- Been thanked: 51 times
I have seen them screwed in with self tappers I think, but the originals were riveted in.
I am wary of screwing in too far and going through the inner sill as well, but what rivets should I use?
I asked mini spares but they don't do them... so any ideas as to suppliers folks? Or neat tricks that you guys know maybe?
Cheers,
Andy
Cheers,
Andy
Re: silly question - best way to fit carpet studs to the sil
I used short pop rivets but in order to close them correctly I used a short length of brake pipe on the nose of rivet gun to enable it to fit inside the stud.
Pretty easy to do I find fitting the other half in the carpet the hardest part
- AndyB72
I did a similar thing to Daz1968 but used a small nut instead of the pipe.
We picked up some short rivets at the NEC Classic Car show.
I need to fit the other bit to the carpet too, not done it before and not looking forward to it.
Somerford list them at 47p each
http://www.somerfordmini.co.uk/eshop/in ... ts_id=1596
or Bresco will sell you 50 for £7.50
https://bresco.com/acatalog/Pop-rivet-f ... F476P.html
As for fitting the parts t the carpet it's fairly easy. When I did it, it was the last thing I did. I made sure the carpet was laying as it should, felt for the top of the stud through the carpet, pushed the bit with the spikes on through the carpet whilst it was over the stud, flipped the carpet over, pushed the round plate over the spikes and then bent the spikes with pliers to hold it all together.
PS As some carpets have a tendency to shrink a little, you might want to let things settle a bit before fitting the studs.
Thanks everyone and that is a great bit of advice toosurfblue63 wrote:Somerford list them at 47p each
I was thinking of using a product like JB Weld.
Any problems?
Any problems?
Roger Williams
- Simon776
The front carpet fixings should be like this. The bracket is welded to the sill and the fastener and spacer are riveted to the bracket - the original is on the left and replacement on the right
The below are normally available but currently out of stock
Excellent - who supplies that type Simon?
when I stripped the car one inner sill was still complete, so I took these off and kept them safe - in the 90s no less. I was was way more organised than I thought back then and tagged everything
So yep, exactly as you say Simon, and am I right in thinking that only the front carpet had the spacers to lift them higher?
- Been thanked: 52 times
After reading about the problem of getting the correct length spacers and rivets I made my own carpet brackets and fitted a anchor nut underneath before spot welding the brackets to the floor. Now I just have to match the bolt length to suit.
Bob's 'super car' triumphs again eh? Your attention to detail is amazing!!
