H beam and bolts - from Specialist Components, £358!
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Post by Exminiman »
Was looking at having S Rods lightened and balanced rather than taking a chance on the cheap H beams, but now SC are knocking them out at £354 inc ARP bolts. :o
50 grams more than MED ETC..but half the price....seems a bit of a no brainer :D
My guess is they must be made in China, but assume SC are confident with them, they have the SC name on them!
Appreciate any comments or experiences (negative or positive ) before i go ahead
https://www.specialist-components.co.uk ... -rods.html
gr4h4m
Re: H beam and bolts - from Specialist Components, £358!
Post by gr4h4m »
They have been some threads over on Turbo minis using the SC rods.
I have a set of the ebay specials Williams branded (but I guess they are all the same). They have seen 8300 regularly in my SA build.. I met a bloke with a race car at Combe who had them at 9600 in the race car for a season.
almondgreen
Post by almondgreen »
This has been discussed here before.
I think the rods are not the problem.
The question is, are the ARP bolts ARP bolts, or just rubber bolts with ARP printed on them.....
Exminiman
Post by Exminiman »
Thanks for the info, to be honest, hadn’t realised they had been supplying them for so long.
I guess there would be some negative comments if there were issues - cant find any so far :?
Lakeland997
Post by Lakeland997 »
I ordered 6" SC rods with non-S big ends and bushes for 18mm piston pins.
They weighed 570g
Because these rods are not designed for 18mm piston pins, the method of modifying them is to press in a thick-walled bush and it adds weight.
When I fitted them the extra width on the beam contacted the edges of the cylinder bores (+020).
I didn't want to grind the bores as the engine was partly assembled so I sent them back.
I ordered Saenz equivalents. They fitted fine and weighed in a 460g each (but also twice the price)
Exminiman
Post by Exminiman »
When they are side by side you can see difference in beam width, not too impressive.
Weight difference is significant as well, 110 grams a rod, or an extra 440 grams spinning around :o
My standard S rods weigh in at just over 600 grams with no bolts , assume 570 grams is without bolts ?
I am only using the Keith Calver Pistons so, standard gudgeon pin dia,
Saenz rods do look nicely made though...did you get from SH ?
251 ENG
Post by 251 ENG »
The specialist components and Chinese maxspeeding rods will both hit the bottom of the boree on +20
Lakeland997
570g was all in with the bolts.
Yes, the Saenz were from Dave at SH Engineering. Swiftune do their version too but were out of stock at that time.
The combination of 6” length with 1.75 big ends is less common because most billet cranks use S dimensions but Dave’s Miglia cranks are modified standard 1275 parts with the 1.75 big ends.
Andy
Exminiman
Post by Exminiman »
251 ENG wrote:The specialist components and Chinese maxspeeding rods will both hit the bottom of the boree on +20
Is that only with the 6” rods ?
251 ENG
Post by 251 ENG »
No that was with std centre rods
Exminiman
Post by Exminiman »
251 ENG wrote:No that was with std centre rods
thats a bit worrying, especially if bores are slightly off line by a few thou....suppose that the benefit of I Beam
