CLASSIC MINI REAR BOOT LID GAPS
MANLEY
Post by MANLEY »
SINCE TAKING 2 YEARS TO RESTORE MY MK 3 MINI ,IVE COME ACROSS SOMETHING I HOPE THE FORUM CAN HELP WITH,SINCE REPLACING THE COMPLETE REAR END WITH A HERITAGE BACK PANEL MY BOOT LID WILL ONLY HAVE A CONSISTENT SMALL GAP ALL THE WAY ROUND WHEN NO RUBBERS ARE FITTED WHEN I FIT THE PROPER RUBBER THE GAP AT THE TOP CLOSE TO THE HANDLE IS DOUBLE THE GAP AT THE HINGE END ,IVE BEEN TO LOADS OF SHOWS AND IT SEEMS MOST MINIS ARE THE SAME.
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Re: CLASSIC MINI REAR BOOT LID GAPS
Post by woodypup59 »
No need to shout old chap ! ;)
But Heritage panels have their faults. They might be made made on original press tools, but those tools are now well worn - being potentially 60+ years old and having made 5 million panels.
The other possibility is that the hinges gaskets are thinner than the original type. Try using two gaskets each side between the hinge and rear panel.
Has thanked: 18 times
Been thanked: 51 times
Are the rubbers stiff perhaps, and the aperture needs tweaking back in a bit to accommodate them?
LarryLebel
Post by LarryLebel »
You've been watching too much TV. Its a Mini. Gaps were never given much, if any, consideration.
