3 Synchro gearbox 1st gear mesh
monte chris
Post by monte chris »
Hi,
I have just recently finished putting together my first gearbox, 3 synchro 22A1288 case with Minispare SCCR gear set, NOS synchro hubs and original 22g202 reverse gear. All spins nice and freely and changes gear with issue, however when I select 1st, it feels like the teeth aren't meshing correctly for what appears to be 1/4 of the laygear rotation. When I mark the teeth where I feel the issue, next time the come around and mess together, the problem appears to of moved to different teeth.
When I select reverse, it feels like none of the gears are meshing correctly on 1st gear. The laygear does seem to rotate freely when selector is put into 'mid-position'. Checking 1st gear, it does have the undercut between the teeth, so I'm a little lost of where the issue is.
Any help or advice would be much appreciated before I start taking the gearbox apart.
Chris
ricardo
Re: 3 Synchro gearbox 1st gear mesh
Post by ricardo »
That would be expected if you had an A type first synchro hub and a B type laygear / reverse. However, I have no idea of what is that Minispare SCCR gear set. I would ask minispares giving all the part numbers you have bought and fitted in the box, they should be able to tell you if that set would work or not. Perhaps you have bought a first synchro for a midget?
goff
Post by goff »
As said by Ricardo , Contact Rich at minispares north , he will be helpfull , best by email.
monte chris
Thanks for the advice and help.
Just been back up to shed and just wonder if any of you with more knowledge on the different types of gear could confirm that 1st gear is 'B' type before I contact Minispares.
Chris
Is it a MiniSpares 1st gear hub or a genuine NOS hub assembly Chris ?
My initial thoughts are that the 1st gear teeth look a little ‘fat’ and could be A type :?
monte chris
Its a genuine NOS 1st gear, on a 22g250 if that makes any difference.
swifty
Been thanked: 34 times
Post by swifty »
The first gear does look as if it's got the undercut
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
ricardo
Post by ricardo »
Show us the first synchro hub from the top, please. The 250 is just the inner hub, doesn't matter in this case.
monte chris
There does seem to be definite undercut on the gears, but here is a picture from the top. I tried to get at least one tooth square on with the camera.
ricardo
Post by ricardo »
That's an A type synchro hub.
iain1967s
Post by iain1967s »
monte chris
Thanks for the help chaps.
Just out of interest, how is the best way to tell if it as 'A' or a 'B' type?
Have a look at Swifty's post with the two gears side by side.
Subtle differences to the shape of the teeth (A type teeth are a little fatter) and also the B type has the teeth 'troughs' slightly undercut.
NOS A type gears are much easier to find than B type, but are easily confused.
Unfortunately BMC didn't bother to stamp the outer gears with a part number very often and as Ricardo has said, the inner hub can be used on either I believe.
1071bob
Been thanked: 52 times
Post by 1071bob »
monte chris
Thanks for all the help.
