Servo location/mounting
DUF2 ‘65 Elf
Post by DUF2 ‘65 Elf »
I am about to fit a servo to my ‘65 Elf.
Which is the best/preferred location to fit & mount the servo?
I would like to install it so it takes up as little space as possible and so that it does not interfere with or make things inaccessible.
Any advice or pics would be great, many thanks.
bwaminispeed
Re: Servo location/mounting
Post by bwaminispeed »
If you figure that out, let the rest of us know, because, we would all like to know that answer........
Basically, they usually go on the right hand flitch panel, above the clutch housing, taking up all kinds of space, and, generally making everything on that side inaccessible or, hard to get at..........
They can be mounted inside as well, under the parcel shelf........
DUF2 ‘65 Elf
What about under the wing? Obviously protected from the elements.
bwaminispeed
That would probably work too, but, a bit awkward to get at to hook up......and bleed.....
Has thanked: 187 times
Been thanked: 65 times
bwaminispeed wrote:That would probably work too, but, a bit awkward to get at to hook up......and bleed.....
Good call on that.
There's also an Air Inlet and Air Filter in most of them too. The Air taken in here, eventually ends up going through the engine, so apart from risking wear to the Servo, it may (likely) increase wear to the engine.
Dearg1275
Post by Dearg1275 »
Some of the last Works cars had the servo mounted under the drivers side wing. The air valve was supplied from a filter under the bonnet so away from the crud. You do end up with a bunch of hoses and pipes to take through the inner wing. These too can be annoyingly in the way.
A good way to go is to arrange the brackets to be quick release in some way and use flexible hydraulic pipes for the brake lines. You can then just throw a thick cloth over the wing and lift the servo out and leave it hanging on the wing while you fix what ever it is you couldn’t get at before.
-mini-
Post by -mini- »
Dearg1275 wrote:A good way to go is to arrange the brackets to be quick release in some way and use flexible hydraulic pipes for the brake lines. You can then just throw a thick cloth over the wing and lift the servo out and leave it hanging on the wing while you fix what ever it is you couldn’t get at before.
Does anyone know if you can buy pre made flexible pipes for this with fittings already attached? Or any advice on what is needed to make them up. Tia.
Dearg1275
Post by Dearg1275 »
If you google custom brake hoses you will find many providers. The company I have used and the quality and finish is excellent.
https://auto.helperformance.com/custom-brake-hose
Best to mock it up first to get your lengths correct before you order. Not cheap.
DUF2 ‘65 Elf
Anyone got a picture of an under wing servo and an under dash servo?
Got a picture of an under rear seat servo. Note accumulator tank.
You can view the rest of the car here
https://www.swva.co.uk/classic-car/aust ... tion-1974/
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Here is how i fit mine. Could even fit sbout 5cm more up...
DUF2 ‘65 Elf
Another silly question!
Can the servo be orientated in any position? Or can it be upside down, on it’s side, on it’s end or whatever?
Fanfaniracing
I think it doesn't matter how it is mounted. I have seen all kind of positions in different cars.
But note that if it is pointing down, it will be more difficult to bleed the air out...
In my experience servos are quite sensitive to orientation, best to stick with the general orientation front to back & rotational that you see in the standard fitment. Servo's can be tricky to bleed at the best of times, you do not need the extra grief of it being in an odd orientation too.
Has thanked: 18 times
Been thanked: 50 times
mk1 wrote:In my experience servos are quite sensitive to orientation, best to stick with the general orientation front to back & rotational that you see in the standard fitment. Servo's can be tricky to bleed at the best of times, you do not need the extra grief of it being in an odd orientation too.
What he said ;-) On our old rally cars we always kept them nose up when located inside.
dodge44
Post by dodge44 »
Don't know if it will help but have scanned and uploaded an original AP Lockheed fitting document supplied with new units back in the 1980's. Note 5 on page 3 states:
'With the aid of the mounting brackets and fixings provided in the kit install the servo unit with the hydraulic slave cylinder outlet port inclined upwards between 25 and 45 from the horizontal plane. (See Fig.2). The air control valve should be situated at least 30 below the centre line to assist when bleeding the hydraulic system. (See Fig.3).'
https://onedrive.live.com/embed?cid=A20 ... k5xGI&em=2
DUF2 ‘65 Elf
dodge44 wrote:Don't know if it will help but have scanned and uploaded an original AP Lockheed fitting document supplied with new units back in the 1980's. Note 5 on page 3 states:
dodge44, that is great, very helpful, thanks very much. I could have dropped a big bollock without that info!!! Most pictures I have seen seem to show the servo as being mounted level, which is contrary to these instructions, so this info is invaluable to me.
As it happens, my servo arrived today, without any fitting instructions, also with the air inlet valve damaged, a replacement is on it’s way.
If a servo is mounted anything but NOSE UP it will be impossible to bleed.
DUF2 ‘65 Elf
Well my new servo arrived today. I have had a quick look and under the bonnet seems rather tight and would make access to the clutch etc awkward.
I had a quick look under the dash in the passenger side and this looks favourite, but the heater is not fitted at the moment. I shall refit the heater and check for space, but suspect this location looks the better place for me.
Fanfaniracing
I have changed my fresh air heater for a small non fresh air hester box.
So i have more Space for the servo under the dash...
Last edited by Fanfaniracing on Fri Dec 06, 2019 10:56 am, edited 2 times in total.
