Morris Cooper grill slat support orientation
Twincam
Post by Twincam »
I disassembled a Morris Cooper grill to straighten some slats and clean up the sheet metal parts that are rusty. I didn't pay attention to the way the vertical channel shaped supports were assembled because I thought they were symmetrical. As you can see in the picture, one end is slightly shorter than the other end. Which end of the support is meant to face the top?
(A former owner had curled up the ends so the grill must have been mounted with an aftermarket quick-release kit. I heated the curled ends to straighten them and reduce the likelihood of fracturing them)
1071bob
Been thanked: 52 times
Re: Morris Cooper grill slat support orientation
Post by 1071bob »
Long section to the bottom.
Has thanked: 18 times
Been thanked: 49 times
Here's the top end of one of mine Gregg. It was fitted with quick release so the bottoms were chopped on this one.
I have a NOS one in my store so can check that tomorrow as well if no-one else confirms.... (edit) but Bob1071 just has ;-)
Twincam
Post by Twincam »
Andy, Are the bottom tabs on your grill cut off or folded forward? I can't tell from the picture. Thanks, Gregg
Twincam wrote:Andy, Are the bottom tabs on your grill cut off or folded forward? I can't tell from the picture. Thanks, Gregg
On this one they have been neatly cut off Gregg.
Has thanked: 127 times
Been thanked: 106 times
Just looking at the pics, even if the tabs have been cut off it should be an easy soft or hard solder fix
Here' another with the lower bits cut off and kept on a piece of string !! Plus the BNIB Leyland one which might be the one to check against - definitely longer part at the bottom ;-)
360gts
Been thanked: 46 times
Post by 360gts »
Trying to find a picture here of my original chrome on brass Morris cooper grille...it has copper rivets on the slats...not pop rivets.
If I can find my picture....will post to the thread.
Twincam
Post by Twincam »
360gts wrote:Trying to find a picture here of my original chrome on brass Morris cooper grille...it has copper rivets on the slats...not pop rivets.
I noticed most of the grills were pop-riveted. Don't know if those were factory or not but I'm pretty sure the semi-tubular copper rivets would have been original because they had the roll formed swage on the front side, where access is extremely poor and probably would have taken some pretty custom tooling to accomplish.
The picture shows me center punching the heads of the rivets prior to drilling out. The rivets were definitely copper and appeared to have a thin tin plating. Tin plated copper rivets used to be quite common because connections in electrical equipment would often rely on rivets.
I'll probably be reassembling with 3/32" aluminum pop-rivets.
Edit: Just noticed AndyPen's grill had roll swaged rivets with the roll swage on the backside. I guess nothing can be assumed about how these grills were made.
There was a specially shaped tool used to support the heads when the solid type rivets were beaten over. Someone showed it on the forum a couple of years ago
My older ones are the heavier plated brass, one I think is the original from the 1071 (more rust) and the other from the race 970.
The new BL version is lightweight - which was one reason I got it. 1972 version I think as a date is on the box.
mellowyellow
Post by mellowyellow »
I,m restoring my grill at present but the fixing holes have broken off top and bottom so i,ll have to make some new bits up. Can anyone give me dims. from the centre of rivit to the centre of fixing hole.
Thanks in advance, Tim
1071bob
Post by 1071bob »
Here you go, the measurements are taken with the grill support 'flat' so you'll have to put the joggle in afterwards for the bottom fixing.
1071bob wrote:Here you go, the measurements are taken with the grill support 'flat' so you'll have to put the joggle in afterwards for the bottom fixing.
Excellent pic - wonder what those dimensions might be in inches Bob?? (12.7 = half an inch for example).
Sorry, what with all this brexiting I couldn't resist ;-)
GraemeC
Post by GraemeC »
1/2”
3/4”
1” & 1/8”
1071bob
Post by 1071bob »
GraemeC wrote:1/2”
3/4”
1” & 1/8”
Correct! :lol:
mellowyellow
Thank you Bob, thats exactly what i need.
Cheers Tim
winabbey
Has thanked: 5 times
Been thanked: 15 times
Post by winabbey »
Does this help?
Just goes to show how amazing this forum is - nice one!!
