can anybody recommend any decent mirrors i can fit to my mk11.
i,ve got a pair of clip on overtaker mirrors at the moment which are ok for pottering around but not much use on the m25.
mirrors
- dhenry
Re: mirrors
http://cgi.ebay.co.uk/Raydyot-Cobra-Des ... 4cf650dcba
I bought one of these and its excellent. I had to extend the groove in the base to get the correct angle but works a treat. Much better than the bullets it replaced. I mounted through the bolt hole for the window catch.
Re: mirrors
that,s a good idea, can you still use it with the window open (assuming you can open the window in the first place.
Re: mirrors
I've got one of those on my Mk2 Woody. I had to drill the window catch slightly to get the mirror thread to go through. I was surprised at good the view in the mirror is as I was expecting it to be a bit iffy. The window operates as normal, but you do have to move your head when wantng to use the mirror.
Re: mirrors
Yep same here Raydot copy, just removed the 8mm fixing bolt and replaced with 6mm then it fits through the window catch.
Cheers Mark.
Cheers Mark.
