Late model magic wand from a mk3 ?
Minisprint!
Post by Minisprint! »
Would a late model magic wand box from a mk3 mini be a four syncro ? Also are they a modified remote box as it looks externally different looks like a remote box with a adaptor plate to hold the gear leaver unlike my original on where the lever goes pratically straight into the box on the diff housing? Got this to hopfully make up a 1275 engine for my van!
nick rogers
Re: Late model magic wand from a mk3 ?
Post by nick rogers »
Yes it will be an 1128 casing. The diff housing is the same on these for wand or remote. The wand is of course different from the early one.
Has thanked: 251 times
Been thanked: 223 times
"While the direct and remote change systems are very obviously totally different, they share the same gear selector mechanism inside the gearbox. From late 1968 when the gearbox went over from 3 to 4 synchromesh, they shared the same differential housing too - prior to that, the direct gearchange had its own unique diff housing with a small gearchange tower on it."
Diagrams here:-
https://www.somerfordmini.co.uk/manual- ... earchanges
The later type magic wand gearlever 22A1382 is also different to pre-68.
Adaptor plate:
