Wet subs for dry suspension.... any mods needed?
sandman
Post by sandman »
Apart from the small brackets/flanges/tabs holding the hydroelements - are there any other mods needed to use a wet frame on an dry setup using dry arms and standard trumpets/struts ?
Someone mentioned to me that the rear frame migth need some cutting??
Cheers,
Ed_
sandman
Re: Wet subs for dry suspension.... any mods needed?
Post by sandman »
Anyone ??
Cheers,
Ed_
guru_1071
Post by guru_1071 »
ed
when i converted my car i just bent the little tabs out the way
no welding required on the rear frame.
the only reason you would do any welding on the rear, would be, i guess to fit the steel 'bump' parts that go behind the rubber cone to stip it going into full compression - as these are not really needed (unless your doing some serious rallying) i wouldnt worry about it - you would probably wreck your shocks before the radius arms could bend back that far
sandman
Post by sandman »
Rich,
Did you use i-lo's or std. trumpets?
From what I can see the [coneshaped] longitudal "slots" inside/behind the trumpets are smaller on a wet sub... A friend of mine was told he had to cut this... does he?
Cheers,
Ed_
Smiffy
Post by Smiffy »
sandman
Post by sandman »
Sorry but what does this has to do with it??
Cheers,
Ed_
guru_1071
Post by guru_1071 »
ed
the hole in the rear frame is bigger so the displacer fits, but this doesnt alter the way the rubber cone or the hilo/ally trumpet fits.
on the front the rubber cone and the trumpet goes in as per the dry, so no change
sandman
Post by sandman »
Many thanks Rich!
Cheers,
Ed_
