Just been getting the Mini Marcos back on the road. Big trouble getting started, finally traced to a fuel starvation problem. The rubber sealing ring at the base of the HS4 carb float chamber that seals the nylon flexi-pipe had perished and just about completely blocked the fuel passage. Can't blame this on unleaded petrol as the tank still contained what must be the last gallon of original 4-star leaded petrol in the UK...
So if you are running HS carbs and think you may have fuel starvation problems here is another place to check.
HS carbs fuel blockage
