Does anywhere sell this bracket?
It's the one that goes between the one that holds the engine mount and the one that holds the radiator.
Or should i bend up a std 850 one?
thanks guys,
James
Cooper S rad bottom bracket
- sandman
Re: Cooper S rad bottom bracket
Minispares sell them... however the last one I bought was not 100% correct when compared to an original... the angles and height varied some.
Cheers,
Ed_
Ed_
- KA2S4
i think ed means top bracket.
the lower ones are avalible from someone on here - 1071bob?
- KA2S4
Bob does the ones to convert your std bottom rad cowl to an S one, but not the bracket in question.
J
J
- YMJ
Excuse my ignorance but when I built up my 1300 engine (preA+ block), I used a standard 850 cowling and the bottom bracket it came with, with no apparent problems. Could this be why I cannot keep it cool?
I made a bespoke top bracket and two small spacers on top of the thermostat housing for the top end.
- KA2S4
YMJ, The bracket won't have anything to do with your cooling problems.
the diferent bracket for an S is simply to move the "bracketry" under the bottom cowl away from the bottom pulley, the cowl and therefore radiator are in exactly the same place for an S or an 850.
You could use the S setup on any mk1, but try using an 850 setup on an S, and those bolts that go thru the rubber gromets will be hard against your bottom pulley.
- Vegard
Tell me about itKA2S4 wrote: You could use the S setup on any mk1, but try using an 850 setup on an S, and those bolts that go thru the rubber gromets will be hard against your bottom pulley.
- sandman
Perhaps Somerford can help... ?
http://www.somerfordmini.co.uk/eshop/in ... ts_id=5923
Although the illustration is incorrect - the part number and description matches the S-version..
Oh - I was dead certain I bought one of Minispares some (5-6) years ago.... but my memory might playing tricks on me.
Cheers,
Ed_
Ed_
