Heater valve woes
Posted: Fri Jun 08, 2018 1:18 pm
I know it's a much debated topic but are there any good heater valves available?. New one just failed after 100 miles or so. I won't hold my breath !.
https://mk1-forum.net/
How does the flange retain the valve ?.mk1 wrote:No, there are no good alternatives at the moment. New ones leak worse than old ones. I have had to resort to these for the moment.
https://www.ebay.co.uk/itm/CAR-HEATER-S ... SwB-1Y2oAj
Ah right, couldn't see a thread in the photo. Parallel thread with the o ring between the two parts ?.mk1 wrote:It screws in.
If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
Does it just regulate the amount of hot water to the heater matrix?
Might just leave it as is, then again with the 850 out and 1330 in I might need the extra cooling capacity on hot days.
Thanks, yeah I guessed as much!111Robin wrote:If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
I knew I had a Mk1 tap somewhere buried in stock, found it, fitted, leaking worse than either of the other two, hence why it was buried!!. Anyway, manual tap ordered, thanks for the pointer Mark.
Sometimes something being seized is actually a good thing !!!!docka wrote:Thanks, yeah I guessed as much!111Robin wrote:If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
If it aint broke...
or if it's only a bit broke, don't fix it or it might get brokener...
I might try one later but I'll go with the manual valve for now.mk1 wrote:Sorry, I should have said that. The late type heater valves from Minispares are fine. These have totally different innards, When I was hunting I wanted something that looked "old".
they are the mega dog shit ones that pull the entire front out when you pull the cable, you can tell by the way the metal disc front is 'crimped' on by the four alloy posts.STG95F wrote:tempted to try ones of these , Has anyone tried one of these or are all this type crap ??
https://www.ebay.co.uk/itm/CLASSIC-MINI ... 1438.l2649
