Heater valve woes
- 111Robin
- Been thanked: 17 times
Heater valve woes
I know it's a much debated topic but are there any good heater valves available?. New one just failed after 100 miles or so. I won't hold my breath !.
- Been thanked: 9 times
Re: Heater valve woes
No, there are no good alternatives at the moment. New ones leak worse than old ones. I have had to resort to these for the moment.
https://www.ebay.co.uk/itm/CAR-HEATER-S ... SwB-1Y2oAj
- 111Robin
I'll just fit that for the moment then. Put the old one back on and it's just as bad. Hopeless.
- 111Robin
How does the flange retain the valve ?.mk1 wrote:No, there are no good alternatives at the moment. New ones leak worse than old ones. I have had to resort to these for the moment.
- 111Robin
Ah right, couldn't see a thread in the photo. Parallel thread with the o ring between the two parts ?.mk1 wrote:It screws in.
And installed.
Think mine’s still got the original valve on but it seems seized.
Does it just regulate the amount of hot water to the heater matrix?
Might just leave it as is, then again with the 850 out and 1330 in I might need the extra cooling capacity on hot days.
- 111Robin
If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
I knew I had a Mk1 tap somewhere buried in stock, found it, fitted, leaking worse than either of the other two, hence why it was buried!!. Anyway, manual tap ordered, thanks for the pointer Mark.
- 111Robin
I fitted this to my Cooper about six years ago and it has been fine so far, don't remember where I bought it though.
20180608_154923 by Robin Derrick, on Flickr
Thanks, yeah I guessed as much!111Robin wrote:If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
If it aint broke...
or if it's only a bit broke, don't fix it or it might get brokener...
- 111Robin
Sometimes something being seized is actually a good thing !!!!docka wrote:Thanks, yeah I guessed as much!111Robin wrote:If it's seized and not leaking just leave it. I unstuck my original one and it has leaked ever since.docka wrote:Think mine’s still got the original valve on but it seems seized.
If it aint broke...
I've had good luck with the heater valve available from Mini Spares-distinguished by the letters MSC on the body of the valve.
Sorry, I should have said that. The late type heater valves from Minispares are fine. These have totally different innards, When I was hunting I wanted something that looked "old".
- 111Robin
I might try one later but I'll go with the manual valve for now.mk1 wrote:Sorry, I should have said that. The late type heater valves from Minispares are fine. These have totally different innards, When I was hunting I wanted something that looked "old".
- Has thanked: 137 times
- Been thanked: 116 times
This must be the archetypal reason for reliability over originality. Reliability and maintainability gets my vote every time!
tempted to try ones of these , Has anyone tried one of these or are all this type crap ??
https://www.ebay.co.uk/itm/CLASSIC-MINI ... 1438.l2649
Not tried one but it LOOKS like it's made from cast ally as opposed to the sintered compressed powder type. That must be a good sign I'd say
- rich@minispares.com
they are the mega dog shit ones that pull the entire front out when you pull the cable, you can tell by the way the metal disc front is 'crimped' on by the four alloy posts.STG95F wrote:tempted to try ones of these , Has anyone tried one of these or are all this type crap ??
