zinc plating on the servo
robert
Post by robert »
i have a friend restoring a 1275 s ,and he is trying to find somewhere to plate the servo in that tumbled gold finish ,he told me what its called ,but stuffed if i can remember ,zinc something or other . :oops:
does anyone know where he might get it done ?
thanks
robert
Smiffy
Re: zinc plating on the servo
Post by Smiffy »
Anodising
Will Grant
Post by Will Grant »
I dont think (neck out here) that gold cad is correct for an Mk1/2 - gold superceded the silver finish late 60s / early 70s? and all un-restored servo's i have seen have the silver cad finish.
The difficultly is getting in replicated, the process is outlawed here bar for aerospace applications, it can be done in the US but i believe the best bet in absence of alternatives is a dull zinc.
Tim
Has thanked: 4 times
Been thanked: 22 times
Post by Tim »
Gold passivation.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Toby
Has thanked: 12 times
Post by Toby »
Cadmium can be still done in the UK, contact EIC:
http://www.eicgroup.co.uk/index.php/Page/Home/gb
T.
mascher
Post by mascher »
He probably mentioned zinc chromate plating. It's pretty common and is often mistaken for cadmium which is much more expensive.
Kelley
Will Grant
Have you used EIC Toby?
66S
Post by 66S »
My plater refers to zinc plating as gold zinc or blue zinc and he does both. Blue zinc goes white as it oxidizes and looks very much like cadmium. In my opinion, gold zinc is wrong for a Mk1, too modern and Japanese looking.
Regards
Al
robert
Post by robert »
thanks chaps ,i passed on the details ,and he'll see whats what .incidentally , the original servo drum , when split into two ,is gold zinc on the inside .
Will Grant
EIC cannot do any CAD plating except for aerospace/military applications.
robert
Post by robert »
sounds like he might be in trouble will , al ,who are your platers ?
one suggestion was that he ask the brake caliper recon companies , because they seem to come back with a new coating of gold zinc ?
Will Grant
I have mine done locally - most plating co's seem to offer zinc, and this is the route i would go down.
66S
Post by 66S »
robert wrote: al ,who are your platers ?
Superb Plating Works but I am in Christchurch New Zealand.
Al
66S
Post by 66S »
robert wrote:incidentally , the original servo drum , when split into two ,is gold zinc on the inside .
Robert, don't take what you found as gospel. During reconditioning, it would be quite normal to have components replated.
Regards
Al
robert
Post by robert »
you lost me al ,do you mean the gold could be a result of a recon years ago ,and therefore not really original ?
Gold or silver passivated zinc are available from any electroplating company in the country. For a very authentic looking Cad type finish you can get a kit from here;
http://www.caswelleurope.co.uk/
http://www.caswelleurope.co.uk/cadzinc.htm
http://www.caswelleurope.co.uk/Scoopercc&z.htm
They also offer a range of other excellent plating kits & accessories. Not cheap, but if you are doing quite a bit its easy & you soon get your costs back.
I agree that most if not all MK1 S's left the factory with a Cadmium plated servo reservoir not a gold passivated zinc one, although as usual I accept that most things are possible.
robert
Post by robert »
thanks al , i think that may be a bit far to go lol.
thanks mark i'll pass that on . i dont think its a mk 1 .
Will Grant
Continued conversation with EIC - can do a Zinc with bright clear passivate, which i looks very close to Cadmium....
cheleker
Post by cheleker »
Thanks, Mark. I was starting to doubt my memory. I've been around a lot of original, Mk I Cooper S cars (English built) over the years and have never seen one with an originally fitted gold servo.
robert
Post by robert »
Will Grant wrote:Continued conversation with EIC - can do a Zinc with bright clear passivate, which i looks very close to Cadmium....
thanks will .
