Wiring a Smiths heated rear screen
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Hi. I used my Mini last week and as is to be expected the rear glass mists up in poor weather. I do have a screen with a fairly prominent late 60's Smiths heated rear screen element (fairly thisk silver bands probably 6mm wide) and I would like to wire it up. I guess I will need a relay, switch etc but as I have never attempted this before I wanted to ask any of the pro's on this forum for advice. Can anybody help?
rolesyboy
Re: Wiring a Smiths heated rear screen
Post by rolesyboy »
Come on you lot. Somebody must be able to send me some instructions. I have the element attached to the screen (thick band silver stype popular in the 1960's and 70's) but nothing else. What do I need to make this work? Cheers. Mark
InimiaD
Post by InimiaD »
Just seen this.
I think I've got a new in box example somewhere.
If I can find it I'll scan the destructions for you.
rolesyboy
Post by rolesyboy »
EXCELLENT. WOULD IT BE WORTH POSTING FOR ALL TO SEE IN THE OTHER SECTION TOO?
Thanks in advance. Mark
999 ORX
Post by 999 ORX »
hello,
I dont think any of the ones ive ever had had a relay with them?
All they had with the kit was a simple switch panel, flick on/off switch and a iluminated light which is wired from the switch with a pigyback spade terminal to show when its on. No fuses or anything. They also have one long bit of wiring to feed the eliment with a live and a short bit that goes to earth (the two terminals on the eliment)
To be honest there only good for keeping you hands warm whilst you push your car! ;) ive never wired mine up properly in fear it will unpeel itself with the heat!
joking aside i would use a inline fuse and a relay if your worried about it
if the other chap cant find his box i will have a root and see if theres any instructions in one of my boxes
InimiaD
Post by InimiaD »
I did find the box yesterday, but I was unable to post anything last night. So this is the 7th attempt.
Not a Smiths type though, but the wiring diagrams should be similar and no sign of a relay.
WAAAHAAAY, it worked. :o
medwaybeat
Post by medwaybeat »
Other than Ebay any ideas on where to pick up a stick on heated element? Smiths would be nice as that’s falling off at the moment.
