Roller Rockers.
Posted: Thu Feb 24, 2011 12:54 pm
Hi,
I’ve got a set Titan roller rockers. All are marked as HL
7 are correct (I think) big bore jobs. LH, LH, RH, RH, etc. But one has the valve bearing in the centre, small bore I assume.
Is the only difference between small and large bore rockers the offset?
If so would it be okay to machine the small bore one so the offset is correct and then pack the bearing with washers / a spacer to the correct position? Or should I get it welded up first?
