Linread Switch
111Robin
Been thanked: 17 times
Linread Switch
Post by 111Robin »
I have a Linread switch where the spring loaded sleeve is jammed down in the housing. I've tried soaking it in WD, tapping it with a hammer and applying a small amount of heat with no luck. Any experts on refurbishing these ?.
Daz1968
Re: Linread Switch
Post by Daz1968 »
Can you rotate it as may be caught up inside, if it's as solid as it sounds from description though may not be salvageable
111Robin
Re: Linread Switch
Post by 111Robin »
The sprung sleeve is fully depressed flush with the domed body so there's no way of getting a hold of it to pulk it out. It's probably scrap but seeing how much these cost i thought it would be worth trying to fix it.
111Robin
Re: Linread Switch
Post by 111Robin »
Disassembled it but had to destroy the nylon insulator block on the end of the pin. Freed off the spring sleeve. I'm trying to reconstitute the insulator with araldite. A lot of hassle for such a small part.
cooperess
Re: Linread Switch
Post by cooperess »
I was wondering how your resurrection was going.
IslandBlue
Re: Linread Switch
Post by IslandBlue »
Intervening period tells its own story perhaps. Sounds like a good lockdown project though, one of mine has died so might take a look.
trevorhp
Has thanked: 16 times
Re: Linread Switch
Post by trevorhp »
If the araldite does not work try this stuff its very adaptable and insulates
We use it for custom work knife handles amongst other things
There are lots of suppliers in various quantities and colours
Its generic name is Polymorph
https://www.ebay.co.uk/itm/100g-Polymor ... 82bc1ef340
Temperatures given in degrees Fahrenheit be careful not to try Celsius :lol:
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
111Robin
Re: Linread Switch
Post by 111Robin »
I honestly can't remember if I managed to fix this, it was for my dad's Triumph 1300.
