LibreOffice developers have been busy and have fixed a problem
that I reported a while back...
Some of the "Help Text" on my Needles and Ratios spreadsheets
has not been rendering correctly on all versions of LibreOffice
after version 3.4.5, so much of this handy information has not been
visible.
The next version of LibreOffice, ie 5.3, is about to be released and
will contain the fix - Watch this space...
In the meantime, I have been working on updated versions of both
Needles and Ratios and would be grateful for a small amount of
assistance/information if any members here can help.
Needles:
Any Stromberg users out there?
I bought the latest charts from Burlen and they list a needle called "45P"
twice, but with two completely different sets of diameter values.
If anyone has a set of needle charts for the Stromberg/Pierburg CD range
and these contain "45P", I'd be pleased to hear from you.
Ratios:
(1) I am looking to update the list of available drop gears and cannot find the
old post about the "economy" primary gear. This had 30 teeth, vs. the 29
teeth of the standard offering, but wasn't there a First Motion Gear with 28
teeth that could provide a double-overdrive?
(2) I currently have a modest list of tyre size (WRPM) values which are used
for accurately working out road speed and also in speedometer calibration.
Any additions to this would be gratefully received, this is what I have already:
(Plus the Dunlops from an ST Manual)
Code: Select all
Selection of Tyres suitable for a Mini
145/80R10: Falken Sincera SN807
Rolling Circumference: 1490mm (1080WRPM)
Source: http://www.falkentyres-uk.com/ (831A 807 fko7eu.pdf Downloaded 25/11/2014)
165/70R10: Falken FK07E
Rolling Circumference: 1475mm (1091WRPM)
165/70R10: Yokohama A008
Rolling Circumference: 1495mm (1076WRPM)
Source: http://www.yokohama.co.uk/Contact-Us (Email Reply 26/11/2014)
145/70R12: Michelin XM2
Rolling Circumference: 1553mm (1036WRPM)
Source: http://www.michelin.in/tyre/viewall/525 (Website Page 26/11/2014)
165/60R12: Falken ZE912
Rolling Circumference: 1535mm (1048WRPM)
Source: http://www.falkentyres-uk.com/ (912.pdf Downloaded 25/11/2014)
165/60R12: Yokohama A539
Rolling Circumference: 1531mm (1051WRPM)
Compiled by Ian Hamilton, from various sources.
E&OE
engined cars may have larger rims. I've also got the 13" Dunlops
from the ST Manual... Spider, wot-u-got?
(3) The latest Ratios spreadsheet contains a fairly comprehensive Speedo Drive
facility which allows users to calculate various options available when messing
about with this sometimes confusing issue.
Is there a comprehensive list of speedo TPM values already in existance?
If not, wouldn't it be great if between us we could compile a list?
Even better if this could contain the scale, eg MPH or Km/h, the number and
position of any indicator lamps, gear change markers and any other information
that would be useful to anyone trying to identify or source a speedo...
I know that this is a busy post, so well done if you've managed to stay with it
so far! Any help would be really appreciated...
Ian
