bonnet jammed!
minitravellerman
bonnet jammed!
Post by minitravellerman »
Any tips welcome!
I've close the bonnet on the Traveller to find that it has jammed in the latch. Any tips on how to release it!! Have been working on it for over an hour and it seems to be well and truly stuck :oops:
Ian Campbell
rich@minispares.com
Re: bonnet jammed!
Post by rich@minispares.com »
you have to get the grill off, then get someone to press the bonnet down why you try and prise the bonnet pin the right way to clear the sliding catch
its a right fiddle
minitravellerman
Re: bonnet jammed!
rich@minispares.com wrote:you have to get the grill off, then get someone to press the bonnet down why you try and prise the bonnet pin the right way to clear the sliding catch
its a right fiddle
That it is!!!
I've been doing what you suggested. We'll get it open somehow - really annoying :evil:
Ian Campbell
swindrum
Re: bonnet jammed!
Post by swindrum »
I once had one so stuck that we eventually had to unscrew the bonnet pin out of the bonnet to release it
minitravellerman
Re: bonnet jammed!
swindrum wrote:I once had one so stuck that we eventually had to unscrew the bonnet pin out of the bonnet to release it
Looking like that's what I'm going to have to do!
Ian Campbell
Re: bonnet jammed!
Sometimes pushing the bonnet down and in or by a sharp tap with the palm of the hand can free them.
swifty
Been thanked: 47 times
Re: bonnet jammed!
Post by swifty »
Get a thin piece of welding rod or coat hanger or even mig wire , curve it into a "U " shape and thread it through the bonnet gap into and out of the engine bay . Twirl the ends together and now you will have something to move the pin to the right position when it will pop up the bonnet . Someone pressing down on the bonnet slightly may also help .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
AWOODY
Re: bonnet jammed!
Post by AWOODY »
Mine does this if someone gets enthusiastic when they shut it so I have to put a screwdriver between the bonnet and the slam panel and give it a gentle tweek or whatever you want , works for me.
