Sun visor hole
Sun visor hole
Hello Guys,
A well known problem with our mk1
The hole for the sunvisor screw had been enlarged by several mounting
Of course I can drill another hole,
But is there an other option?
I was wondering, If I could find plastic insert to put in, and use original screws,
Does someone know where I can find this?
Thank you
Charles
Thank you
Charles
- 111Robin
- Been thanked: 18 times
Re: Sun visor hole
Do a search for rawl nuts. These are inserts used where there is no access from the back to use a standard nut. You do need a certain clearance for the length of the insert so not sure if it'll work but they're cheap so worth a try.
Re: Sun visor hole
I think that as above, rivnuts are probably your best option. Any nylon type plug would inevitably work loose.
- rich@minispares.com
Re: Sun visor hole
that drawing is incomplete
where is the picture of a 'incorrectly installed rivnut, followed by loads of swears.....'
- Matt_Tupman
Re: Sun visor hole
Hello Guys,
Thanks for your reply,
I already thought to rivnut but, it's a tidy area
The hole is about 6,5 mm
And the rivnut clamp is too expensive for me
A last idea is a plastic insert "hammered" it could be an option
Re: Sun visor hole
There is a Nylon insert that the screws for the voltage regulator screw into on the inner wing. If you could obtain one of these then I am sure you would be able to adapt one.
I have just checked in the parts list & its part No 13H 226 "Nut-Screw"
A rivnut would be better though, if you can find someone who can put one in for you.
They aren't that expensive;
http://www.ebay.co.uk/itm/4mm-8mm-THREA ... xyTP1SOD44
£11.00
£11.00
- 111Robin
Re: Sun visor hole
The rubber rawl nuts don't require special tooling and are very cheap. If the other two screws are ok this should be sturdy enough. There are dozens of these on the Elise. Granted they are a PITA if they start turning if you want to remove the screw but a dremel cutting disc easily sorts that out.
Re: Sun visor hole
Hello
I finally bought this morning a insert tool!
It's done!! very easy!!
let's go for the nextstep!!
