Engine lift brackets
Lefty
Post by Lefty »
Hello: I have seen two types of engine lift brackets: those that attach to head bolts and some that attach to rocker cover bolts. Any views on which is the better?
Thank you
November 1965 Austin Cooper 998
1963 Austin Countryman woodie
1071 S
Re: Engine lift brackets
Post by 1071 S »
I have a small length of chain that connects two modified spark plugs - that go into the No1 and 4 plug holes..
Works really well. .. and could be easily replicated with a few simple hand tools.
Cheers, Ian
dklawson
Post by dklawson »
I have used the rocker cover bolts with a ratchet-tie-down strap down the back of the block to control the angle of tip. The rocker cover studs are plenty strong enough... just don't let it swing violently.
I also made a set of the spark plug lifting eyes that Ian mentioned. They worked OK but I felt I had more control using the rocker cover studs.
Though many people use the head stud lifting brackets, the concept has always bothered me. After all, you are loosening and then re-tightening a head stud which just seems so counter-intuitive to what you would normally do.
Doug L.
The ONLY one to use is the official thing that bolts to 2 front cylinder head studs, these have 2 positions tilted & straight & make fitting an engine (almost) a joy.
I believe that M-Machine sell a replica (although I can't find it in their catalogue), but original can sometimes be picked up on ebay.
viewtopic.php?t=11467
Just found one at Minisport
http://www.minisport.com/tol001071-mini ... -tool.html
rich@minispares.com
Post by rich@minispares.com »
mk1 wrote:make fitting an engine (almost) a joy.
I bet they don't make removing a recently fitted engine a joy...... :cry: :cry: :cry: :cry: :cry:
TRUE!
:roll:
jerry
Post by jerry »
I think Sykes-Pickavant make ( or used to) the brackets that bolt to the head studs. I borrowed one, measured it up and made my own. Works a treat. Dont trust two 5/16" threads to lift the weight of the engine, plus the weight of the front of the car when you've forgotten to disconnect the earth strap..... :shock:
Jerry
goff
Post by goff »
1071 S wrote:I have a small length of chain that connects two modified spark plugs - that go into the No1 and 4 plug holes..
Cheers, Ian
This is the one , Two old spark plugs works a treat, Used this idea in the late 60s.
ianh1968
Post by ianh1968 »
jerry wrote:<SNIP>Dont trust two 5/16" threads to lift the weight of the engine
:shock:
The bolts are stronger than you might think...
viewtopic.php?f=3&t=11774
Ian
(PS Nobody was really taking the piss, it was just my warped way of making the point).
GraemeC
Post by GraemeC »
I've always just used one BMC bracket bolted to the centre from head stud.
Gets the angle of the dangle just right and if you're not too proud of the looks you can fit an extended stud so you don't need to loosen the nut, just bolt the bracket on top.
timmy201
Been thanked: 42 times
Post by timmy201 »
GraemeC wrote:I've always just used one BMC bracket bolted to the centre from head stud.
I do the same :)
jerry
Post by jerry »
:shock:
Ian
I was aware the yeild strength was quite highish for the small stuff, but the problem is I work in a power station where the smallest bolts are usually around 5/8", up to 6" diameter bolts, so im just used to big bolts, torqed to hundreds of ft/lbs Looked at kit areoplanes in the past and the whole Rotax power units are bolted to the airframe with just four 1/4" bolts. Obviously strong enough, but dosn't always look so...
Smiffy
Post by Smiffy »
It's not usually the bolt that fails, it's the casting that breaks around the bolt……...
