Hi All
Is it still possible to purchase the demister vent hose that runs from the heater to the vents on the top rail (1965 Elf)
All advice welcome on fitting the black vinyl cloth on the top & bottom rails
Spray mount or Evo stick, glue both side or one? Cutting the vinyl
Unfortunately the head lining has been damaged, advice on fitting
The radiator top bracket appears to be about an inch short, were it is held by the screws on the top of the rad
On trail fitting the rad onto the engine out of the car, if we push the rad over to line the holes up, the fan touches the rad on the inside.
Engine is 1275 A+ fitted with minispares rad brackets & cowl
http://minispares.com/product/classic/ARA2770.aspx
http://minispares.com/product/classic/12A361.aspx
http://minispares.com/product/Classic/12A2153.aspx?
12G617S
Rebuild Questions /Demister/Vinyl/Head Linning/Rad Bracket
- Has thanked: 18 times
- Been thanked: 17 times
Re: Rebuild Questions /Demister/Vinyl/Head Linning/Rad Brack
Google 'rsn mk1 blog spot'. It's a great blog on the build of an S and I think there's a section on the vinyl, or there's another cracking build on here under our cars....
