New Wiring Loom Advice
100BUR
Location: Cumbria, The lakes, were the roads are always quiet, and the sky is nearly always blue
Post by 100BUR »
I am looking for advice on what new wiring loom to purchase for my modified 1965 Elf, that will require the least amount of botching!!! :lol:
Spec of Car
1965 Elf Centre 3 clocks
Side lights (As standard Elf)
Alternator
Pre Engaged Starter
Electric Fuel Pump
Ideally I would like to fit a Tacho & 2 speed Wipers
Thanks :D
rich@minispares.com
Re: New Wiring Loom Advice
Post by rich@minispares.com »
why don't you just special order a loom direct from autosparks that has all your requirements ready built in.
its not that expensive and makes the job right
As above.
swifty
Been thanked: 43 times
Post by swifty »
A couple of years ago I had auto spark make me a loom for a mk1 S , alternator , and wired for a Innocenti dash ! ... They wired it for early or late rev counter as well . All the extra wiring cost was £25 , bargain . I never got round to using it and sold it to a fella who said everything worked fine .... They did this work based on some close up pictures I emailed them on the back of the clocks ........ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
phil.1380
Post by phil.1380 »
While none of your requirements are particularly onerous if you want to retain a cotton-covered loom I also advise getting Autosparks to do it all.
If you already have a taped loom then maybe go for it yourself. A later model car, say 1984 onwards would have all required bits already in the front harness. That loom would have modern plastic plugs for switches and stalks, and nothing for an electric fuel pump. Wouldn't the Elf's rear harness already have provision for a lecy pump ??
I've been working on a 1935 Austin 7 Ruby recently with a new Autosparks loom, and it just fits and works as it should. They do great products at a very reasonable cost IMHO.
Phil.
100BUR
Post by 100BUR »
Thanks for the replies
I was unaware of Autosparks, looks to be quality kit
Will drop them a line for a quote
stratmankev
Been thanked: 12 times
Post by stratmankev »
Rapidfit looms is another option, I've heard lots of good things about them although they do seem a little more expensive than autosparks, I am about to order a new loom for my mk2 cooper and haven't decided where to get mine from as yet?
