poly windies
thefarmer
poly windies
Post by thefarmer »
How well are these supposed to fit in a Mk1?
I received (a while back) a set of windies from a supplier for a Mk1...the quarterlight windies, I had to shave quite a bit off to fit in. For the door windies, I haven't touched at all, and just inserted. They seem quite loose and you can physically lift the windie 'in situ' 4-5 mm up and down. I'm using my original upper window channels, and sliding window catching lock runner, but replaced the lower sliding window runner.
I'm not too concerned, as it's on a rally car and therefore not exactly known for concours quality/finish...however, is it just me, or is this standard for poly windies?
By the way...quality is great and I can't believe how light these things are.
Thnks,
Ben
Re: poly windies
It's all Greek to me
pad4
Re: poly windies
Post by pad4 »
Theres 3 different sizes for the rear 1/4 windows - bolt in ones that use no rubber trim or frame, ones that fit in a rubber seal like an 850 and ones that fit in the chrome opening frame so you should have had the choice which ones you wanted - if you trying to put any of the first 2 in the frames you will have to take material off
the mini spares lower channels wont make to much of a difference so you shouldent really have that much movement in them, just measure them against a piece of glass
pad4
MiniMark1
Re: poly windies
Post by MiniMark1 »
Try these people - http://www.acwmotorsportplastics.co.uk/ they have all the templates and the windows fitted my car first time with no adjustment. Hope this helps. Cheers Mark
Re: poly windies
Pad4 is too polite to say but he has more than a bit of knowledge on this subject.
http://www.plastics4performance.com/
pad4
Re: poly windies
Post by pad4 »
Aye Mark- well ive made one or two sets over the last 15 years or so - but there are always a few odd ball things that appear with minis which need adjusting, we even get surprised to this day with them.
But yea - they are light compared to glass - 50% lighter and cheaper than a diet
Got some special ones on my own car for Blyton - Anti-Scratch, Anti-fog and and solar control ;-) WRC slider kits fitted which arnt exactly period but hell - why not
pad of P4P
sandman
Re: poly windies
Post by sandman »
Solar control what??
Please tell me more Pad!
:D
Cheers,
Ed_
pad4
Re: poly windies
Post by pad4 »
Top Secret sorry - cant say too much at the moment or all the other oiks will start trying to copy our stuff AGAIN
:shock:
Pad
nick@dunsdale
Has thanked: 12 times
Re: poly windies
Post by nick@dunsdale »
surfblue63 wrote:It's all Greek to me
windies = window
canny = cant ( not canny by nature)
Hen = female ( not the type that lay eggs)
example " alright hen can you look oot the windie i canny get up "
Scottish chatter lol :lol:
rich@minispares.com
Re: poly windies
Post by rich@minispares.com »
pad of P4P
do they make the clutch work as well? :lol:
smithyrc30
Re: poly windies
Post by smithyrc30 »
windies = window
can nae = cant ( not canny by nature)
example " alright hen can yea look oot the windie i can nae get up "
editted Scottish vocalisms. :D
Re: poly windies
windies = window
Och, yer di nae say!!
pad4
Re: poly windies
Post by pad4 »
rich@minispares.com wrote:
pad of P4P
GROW UP - pervert
wantafaster1
Has thanked: 18 times
Been thanked: 11 times
Re: poly windies
Post by wantafaster1 »
You forgot about the special clevis pin fitting attachment Paul.
rich@minispares.com
Re: poly windies
pad of P4P
GROW UP - pervert
:lol: :lol:
watch it, or I will tell tales on you to your missus
then YOU will be in trouble :lol: :lol:
pad4
Re: poly windies
Post by pad4 »
DONT you dare tell her Micky B has been shopping at minispares for my 8 port :roll:
wantafaster1
Re: poly windies
Can you just not pretend it was only a couple of hundred quid?
