Supposedly the A series is highly susceptible to the rings not bedding (according to Lord Des) and he recommends WD40 on the bores. However I was told by my 'engine man' never to use WD40 as the rings will not bed in due to it containing silicone (never realised it did). So there are 2 diametrically opposite bits of advice
My gut tells me just to lightly oil the bores with standard engine oil and ensure the motor is not 'babied' in the initial miles - run it straight away, don't labour it, and allow cylinder pressure to do the work. This has always worked before, albeit on other engines.
Spider - as ever your wise advice would be welcomed!
Here's another one - the dark world of cam bedding. My new Kent cam and followers were supplied with no lube - I'm using Redline assembly lube everwhere else (save for the bores of course). Redline do not specifically mention this lube in the context of cams - can I use it for that purpose or do I require the 'made for purpose' stuff?
As ever, thanks in anticipation.
Jon
