What size fuel line?
Posted: Mon Oct 12, 2015 9:59 pm
by rolesyboy
What size is standard fuel line? 1/4 ?? Would it matter if I used 5/16? Cheers. Mark
Re: What size fuel line?
Posted: Mon Oct 12, 2015 10:58 pm
by minimans
Yes and No! Std is 1/4 and 5/16 wouldn't hurt but bare in mind the outlet from the tank is 1/4 and the fuel pump Inlet and Outlet are a 1/4 so really unless you enlarge these at the time of fitting 5/16 there's no benefit either.......................
Posted: Tue Oct 13, 2015 10:52 am
by ianh1968
If using both 1/4" and 5/16" in the same system, this hose might be useful:
http://www.carbuildersolutions.com/uk/fuel-hose-7mm-932
I've used it myself with good results - By coincidence, I shall be buying some
more today...
Posted: Tue Oct 13, 2015 11:20 am
by rolesyboy
Thanks folks. I have a roll of 5/16 kunifer on the shelf.
Posted: Tue Oct 13, 2015 1:50 pm
by swifty
I always thought the outlet pipe from the tank was 3/16th but a 1/4 flex hose was used to the fuel pump and from the pump to the front of the car 1/4 pipe . ... I've been wrong before
.... Ken
Posted: Tue Oct 13, 2015 2:09 pm
by rolesyboy
Anybody want to go any lower??
Confused from Essex!
Posted: Tue Oct 13, 2015 2:19 pm
by smithyrc30
The standard outer diameter as far as I recall is 1/4", which means with the pipe wall thickness the bore is 3/16".
A far cry from a 1965 Ford Galaxy 500 I had which ad 1/2" fuel lines....
Posted: Tue Oct 13, 2015 3:18 pm
by ianh1968
smithyrc30 wrote:The standard outer diameter as far as I recall is 1/4",
In "old money", the bore was always quoted as the size...
For example a 1/4" BSP fitting would be the one to use with a 1/4" BORE tube.
However:
When "Metric" came along, particularly in domestic plumbing, it WAS the OD
that was quoted as being the pipe size.
This is why 1/2" plumbing tube is almost the same "size" as 15mm tube...
Conclusion:
The pipe with an outer diameter of 1/4" should probably be called 3/16" pipe!
