Hi there - My Cooper is so close to being finished - but have an oil leak I just don't seem to be able to solve.
I am running Cooper S Driveshaft outputs with Hardy Spicer joints. I have oil leaking out the seal around the gearbox output. I have replaced the seal and have fitted a NOS union (the bit that goes into the gearbox). However I think I need to replace the bronze bush in the output flange - theory is that the bush is worn and the circular movement in the gearbox output union is allowing oil to weep past the seal - make sense!?!?
Can you buy new Bronze Bushes? If not - does anyone have any NOS ones they would be willing to sell? Or finally failing that does anyone have an output flange for the radiator side of the engine with a good bronze bush.
Many thanks
Mark
Cooper S Gearbox Output Frange Bronze Bush
Re: Cooper S Gearbox Output Frange Bronze Bush
Minispares sell the new bushes, but they will have to be reamed to size.
Many thanks for this - I will ring them in the morning - I had been told that they didn't make them for the Cooper S specific output flanges.
Many thanks
Mark
Many thanks
Mark
I've just had a look on their site and it appears the bushes are out of stock. Give Minispares North a ring, sometimes they have items in stock that aren't on the main website.
- Vegard
Have you fitted the sealing ring underneath the centre bolt and washer to prevent oil leaks ?
I couldn't get any 22G420 flanges when I built my car and didn't want the different shaped rod change flanges. I used some standard covers and got them machined out to take the larger S bushes.
Before anyone comments, I know that there isn't a lot of material on a standard flange compared to an S flange once machined to take the S bush and seal, but 9 years and about 7000 miles later, I've had no problems and no oil leaks.
- spoon.450
That's good to know Andrew, I've thought of doing that before but never got around to it. I did buy some S ones from Minispares within the last year though.Andrew1967 wrote: I used some standard covers and got them machined out to take the larger S bushes.
Thanks all for the advice and suggestions. Ive spoken to Mini Spares North today and have one winging its way to me
Yeah - have fitted the rubber washer behind the big bolt as well as the small half moon washers.
Hope with a bit more work and reaming the bearing to size the job will be complete.
Next job it to fit the Radford centre consul Ive just had delivered from Steve B
Are these cars ever classed as finished!!!!!
Thanks again
Mark
Thanks again
Mark
- Has thanked: 208 times
- Been thanked: 80 times
I've done a few of these. I go through the covers as some as cast different with more meat in them (I'd say for S sized bushes and seals) but only fitted with the smaller bushes. I can see that you'd be able to do the same with the 'smaller' castings, but I'd be worried they'd be a wee bit thin, then again, you've not had trouble in 9 years / 7000 miles!Andrew1967 wrote:Have you fitted the sealing ring underneath the centre bolt and washer to prevent oil leaks ?
Good to know!
