oil seal problem
Charlynsane
oil seal problem
Post by Charlynsane »
Hello guys,
I have some trouble with my MK2 cooper,
The clutch oil seal is leaking,
I remove the clutch cover (the engine is the car)
Should i remove the engine to remove the flywheel?
How can i remove the old oil seal?
surf-blue-850
Re: oil seal problem
Post by surf-blue-850 »
Can be done in-situ.
Take care when sliding the seal over the primary gear, it's easy to damage the seal. Try and get the proper tools or wrap the gear with tape to slide the seal over. While you're at it, check the end float of the gear, too much can cause oil to leak.
Charlynsane
thank you very much,
What is the best flywheel puller, mine is fitted for 40 years..
maybe kad?
surf-blue-850
I've got an old sykes one I think. Belonged to my Dad, never let me down so far.......
GraemeC
Post by GraemeC »
Guessworks sells a nice heavy duty puller
Charlynsane
thank you guys,
is the seal difficult to be removed?
I will try to find the the tool to fit it without damage
thanks
Has thanked: 208 times
Been thanked: 80 times
I'm pretty sure the GW puller doesn't fit in the car. The Hydraulic ones are the go, never fail.
Charlynsane wrote:thank you guys,
thanks
The easiest way is with a Primary Gear Puller, I made mine about 30 years ago, however these guys sell something similar
http://minisport.com.au/mini-primary-ge ... oving-tool
As you pull the Primary Gear, the seal will come with it.
Then when refitting the new seal, these are a handy and easy to use bit of kit
https://www.minispares.com/product/Clas ... 0to%20shop
GraemeC
Post by GraemeC »
It might not, although it doesn't look much bigger than a SP one which does.
Hydraulic are great - but not easy (or cheap) to come by.
I seem to recall John himself saying they didn't fit in car.
Looks a nice bit of kit though.
ianh1968
Post by ianh1968 »
Spider wrote:The easiest way is with a Primary Gear Puller, I made mine about 30 years ago<SNIP>
Does it look anything like this, also made about (almost exactly) 30 years ago?
This was made in a bit of a hurry as a primary gear had seized itself to the crank
of the Marcos engine when it was first built.
TOP TIP:
May sound like a stupid thing to say, but don't forget to remove the 'C'-clip
and retainer ring before use or your efforts will be in vain...
(My brother once tried to remove a flywheel using a puller, but forgot to take
the key-plate out first. He kicked himself when I pointed out his problem.)
:oops:/ :lol:
Ian
Ian, very very nice, very nice indeed. Much better than the original BMC tool.
Mine is nothing remotely as nice as that and now I see yours, I'm glad I didn't post a picture of it!
You do realise that I'm gunna have to steal the idea though, don't sweat it, I'll be sure to let my mates know I thought of it :mrgreen:
Charlynsane
Hello guys,
I will try to remove the seal my a thin screawdriver, very carefully, the tool is very expensive
I will buy a puller for the flywheel and the tool to put the seal... first time for me..
Supersonic
Post by Supersonic »
Charlynsane wrote:Hello guys,
Try and get your hands on a Sykes-Pickavant 851X clutch & flywheel puller kit if you can. I have this kit man & boy over 40 years :D :D
Oz67Deluxe
Post by Oz67Deluxe »
No need for a puller! Punch a small hole in the seal then screw in a suitable self tapper screw. Then grab the screw with multigrips etc and yank on it. Viola, seal pops out. Don't mess about with screw drivers, you'll damage something...
Charlynsane
Hello Guys!
Good idea!!
I will do this during the week end!
cheers
Charles
Charlynsane
Hello guys,
I managed to remove the flywheel and the clutch but not the oil seal.
I'm looking for a primary gear puller
thank you
Charles
Charlynsane
Hello guys,
Still looking for a puller
viewtopic.php?f=8&t=13769
If I remember today, I'll post up photos of mine, not nearly as elaborate as Ian's but gets the job done.
I made it probably 30 years ago, long before I had any machines, apart from materials, all you need to make one is a hacksaw (or grinder), a hole saw and a welder.
Charlynsane
Hello,
Unfortunately I don't have welder
I'm still searching
Charlynsane
Hello
I found my tool on ebay..
55 pounds including shipping!
Expensive But i need it quickly to finish my father's engine
