Z cars are advertising a Mini with the Ford Ecoboost engine
Is this a good alternative for the good old "A" series?
What is involved in fitting the Ford engine
126BHP in a modern engine setup does sound appealing
Ford Ecoboost Engine
- gs.davies
- Has thanked: 75 times
- Been thanked: 77 times
Re: Ford Ecoboost Engine
Very interesting - these modern three pots are really coming along. The Ford unit has a block the size of a sheet of A4 paper and weighs almost nothing.
I'd be interested to see a conversion for the Mini that uses the BMW B38 1.5 Turbo engine, as seen in the BMW i8. In that car it pumps out 230 or so HP. In the current Mini Cooper it's 136HP. With a load of low down torque, it'd make an original mini absolutely fly!
I couldn't believe it when my other half came home with one of these for a work trip.....A 1.0 Litre Focus, it must be a proper slug I thought....She started it up....3 cylinders?..., I wasn't at all convinced, but having driven it I thought it was a great little engine, 125HP from a lightweight production 1.0L is impressive, I suppose it will remain to be seen if it gives the Ford warranty department a few headaches. Yesterday I drove the new 1.2L 3 cylinder Skoda Fabia......now that is a slug.
- smithyrc30
3 cylinders bore 71.9mm stroke 82mm....
They also do a Red edition Fiesta with 138bhp (140ps) version of the 1.0l engine.
http://www.at.ford.com/news/cn/Pages/Ne ... 0Ever.aspx
The engine block is cast iron:
http://www.svtperformance.com/articles/ ... _T_007.jpg
Engine in bits:
http://images2.cardekho.com/images/carN ... /ford1.jpg
Block in carry on luggage, not sure I'd want to lift it into the overhead bin though...
http://images.dailytech.com/nimage/ecob ... itcase.jpg
Engine in bits:
- smithyrc30
Just found there is an M-Sport version with 170ps:
http://www.carscoops.com/2015/03/ford-f ... s-10l.html
Engine weighs in at 97kgs (not including gear box or ancillaries):
http://www.autoevolution.com/news/ford- ... 56142.html
38 psi boost, and 240,000 rpm turbo! Inspired choice of bore and stroke too!
