Indicators not working when lights are on
robbyasti
Post by robbyasti »
I have a 1968 innocenti mini 850. After being off the road for a few years, I finally took it for a spin today. All ok apart from the indicators. They work fine when the headlights are off but as soon as I switch on the lights, the indicators stop working. I don't think that the dynamo is faulty because the lights remain very bright and the battery recharges.
The battery is new and fully charged.
swifty
Been thanked: 41 times
Re: Indicators not working when lights are on
Post by swifty »
When your indicators are on , you obviously have a live and earth going to them . So put your indicators on and turn on the headlights . In your case your saying the indicators will not work with your headlights on ...... So put a tester on the indicator wires to see if it's the live or earth wire which is not working .9 times out of 10 it will be the earth wire . If it's the earth you can simply run another earth to the shell .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
robbyasti
Post by robbyasti »
swifty wrote:When your indicators are on , you obviously have a live and earth going to them . So put your indicators on and turn on the headlights . In your case your saying the indicators will not work with your headlights on ...... So put a tester on the indicator wires to see if it's the live or earth wire which is not working .9 times out of 10 it will be the earth wire . If it's the earth you can simply run another earth to the shell .... Ken
Thanks Ken. I will try it tomorrow.
