quarterlight window help
Posted: Thu Aug 13, 2015 4:39 pm
by twodoor64
I have a 1964 S. I need help in how to disassemble and assemble the chrome frame around the window. All help would be greatly appreciated.. Mike
Re: quarterlight window help
Posted: Fri Aug 14, 2015 3:16 pm
by Dr S
I've not taken one apart but from a partial disintegrated one I have, there are a couple of rivets on the bottom side that join the two ends together. I'd drill these out and then just gently work the frame out. I suspect you can't get the rubber seal in the frame so I'd build back up with some black mastic in there.
However, I'm sure I've heard of people swapping the hardware and brackets about to make the drivers side fit the passenger and vice versa giving some better chrome for the outside...
Posted: Sat Aug 15, 2015 12:03 am
by LarryLebel
I've had 2 MKI Minis. In both Minis the frames are held together by 2 small counter sunk screws on both ends of the hinge.
Posted: Sat Aug 15, 2015 6:48 am
by coop12g295
Re the rubber for 1/4 lights I had access to glazing strip rubber on a roll
but this size is now deleted from suppliers catalogue.If I have to do another
I may try commercial/plant inner tube and trim after fitting
Posted: Sun Aug 16, 2015 3:39 pm
by twodoor64
Hi
Thanks for the input.
It's my understanding that MR2 1/4 light frames are different. Mike
Posted: Mon Aug 17, 2015 10:20 am
Larry is correct. Undo the 2 small cross headed screws at either end of the hinge & they fall apart quite easily. The difficult bit is getting the screws out.
Posted: Mon Aug 17, 2015 4:08 pm
by cheleker
Dr S, for English built cars, at least, the single connection in the bottom middle is Mk III and later. Mk II (the worst ones) have top and bottom in the middle. Mk I is the front hinged version as mentioned by others.
