Seat Belts
Posted: Fri Jul 24, 2015 5:13 am
by Spitz
My new to me 62 Traveller does not have seat belts. It does have the high up mounting point with a bolt in place on both sides of the car.
Can I assume that they were an option for the NA market that early?
I see no fittings at the bottom ( although I've not pulled back the carpet )
Re: Seat Belts
Posted: Fri Jul 24, 2015 7:51 am
by Old English White
The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
Re: Seat Belts
Posted: Fri Jul 24, 2015 9:19 am
by Tupers
The 2nd mounting point should be on the inner sill just in front of the rear bin.
You can just about see it in this pic.
Re: Seat Belts
Posted: Fri Jul 24, 2015 9:23 am
by Pete
As Richard says, belts were a dealership or aftermarket option in the early 60's.
Re: Seat Belts
Posted: Fri Jul 24, 2015 1:48 pm
by Spitz
Thanks for the replies…….but would the factory put the bolt in place (upper)
I'll have a look for the bottom mount later today
I've not been able to find out if belts needed to be fitted here in CA at that time.
Re: Seat Belts
Posted: Sun Jul 26, 2015 8:48 am
I think they left the factory with a plastic grommet in the upper mounting hole if memory serves me? Not a bolt anyway.
Re: Seat Belts
Posted: Sun Jul 26, 2015 9:41 am
by Gareth Brandt
High mounting had a washer (24A 1356) and metal clip button (14A 9631) lower had a plastic bolt (14A 9922) and tunnel had rubber gromets (14A 9668)
Re: Seat Belts
Posted: Sun Jul 26, 2015 10:29 am
by Pete
Old English White wrote:The mountings were fitted by then (the lower one will be behind the carpet) but belts didn't become a compulsory fitting in the UK until 1965 I think?
The rule was that by 1965 if your car had been registered in that year you had until December to put belts in and compulsory thereafter.
