rocker shaft bungs
- Has thanked: 11 times
rocker shaft bungs
Hi,
removed the bungs in the rocker shaft for cleaning. Does anywhere sell these? Or is it a case of making them?
Re: rocker shaft bungs
Hi Mark, ive had a good look round in the various mini suppliers with no joy. Guess id better get some brass bungs made.
The ones that go in either end to stop the oil from "falling out". TBH, I have never heard of anyone removing them before today.
- JohnA
- Location: Up north where men are men and sheep are frightened
Why not buy a new shaft? They are only £12.00 inc vat from minispares, not worth messing about.
I has assumed that this was a new shaft that had had the bungs removed. If it is an old one then I agree, throw it away 7 use a new one. I never do a top end / engine rebuild & keep the shaft, as far as i am concerned its a replaceable item.
Hi,
yes it is a new shaft.
I've previously had some maching swarf come out of the oil hole prior to assy. So i now remove the bungs to remove any internal burrs and make sure its clean.
Just trying to save a bit of time making the bungs.
Sounds like a good plan if you have successfully found it before.
Maybe ignorance isn't bliss
- JohnA
- Has thanked: 206 times
- Been thanked: 79 times
JohnA wrote:Maybe
5portsrock wrote:
Maybe what ?
