Turbo cranks CAM6581
Posted: Mon May 18, 2015 7:42 am
by Vegard
I've read this:
http://minispares.com/product/Classic/E ... .aspx|Back to search
And worked with a heap of them. The turbo ones always seem in better shape then the regular A+ ones. Does anyone REALLY know the history about these cranks? They wouldn't have bothered with a different forging/casting number if the only difference was the hardening would they?
Different steel?
Re: Turbo cranks CAM6581
Posted: Mon May 18, 2015 10:54 am
I don't have much info on these, but it seems they had normal ground fillet radius on the journals and made from EN16T (which can Tuftrided).
The later Cranks have the Rolled Fillet radii and so was deemed not necessary to Tuftride these, though they are also made from EN16T and can be.
Posted: Mon May 18, 2015 11:41 am
by Vegard
Spider wrote:I don't have much info on these, but it seems they had normal ground fillet radius on the journals and made from EN16T (which can Tuftrided).
Why did they use a different forging then?
Posted: Tue May 19, 2015 1:36 pm
by 69k1100
Higher capacity oil pump?
Posted: Tue May 19, 2015 9:43 pm
I don't have factory info on that, but going off some of the other things they did, it may have been to distinguish between a ground radius and rolled radius types.
