Bad Luck
Posted: Mon Nov 22, 2010 1:47 pm
by 970s
Re: Bad Luck
Posted: Mon Nov 22, 2010 1:52 pm
OUCH!
It looks like the owner had a very lucky escape all things considered.
Does anyone know why short stroke cranks usually go there?
Re: Bad Luck
Posted: Mon Nov 22, 2010 2:00 pm
by guru_1071
mark, id guess either a poorly balanced flywheel, or poor primary gear clearance - which cooks the oil at that end
my 970 broke at the same place
Re: Bad Luck
Posted: Mon Nov 22, 2010 5:19 pm
by InimiaD
That pic brings back BAD memories.
I snapped a crank, same place as in the pic and that was a 1275 semi s/stroke.
Saved everything except for a crankshaft, obviously, and a flywheel housing.
Re: Bad Luck
Posted: Mon Nov 22, 2010 7:14 pm
by 251 ENG
That,s the point where all the load is from engine to transmission .
Bet any money it started with a crack in no4 fillet radius .
Also looks quite an old crank design , has it been reground ?
Bad grinding of fillet radius is a sure way to kill a crank .
Re: Bad Luck
Posted: Tue Nov 23, 2010 12:42 pm
by 970s
Re: Bad Luck
Posted: Tue Nov 23, 2010 10:12 pm
by 1071bob
Yep,
Re: Bad Luck
Posted: Wed Nov 24, 2010 8:20 am
Nice picture, but a very nasty looking crack.
Did you get that done at work Bob?
Re: Bad Luck
Posted: Thu Nov 25, 2010 12:06 am
by 1071bob
mk1 wrote:Nice picture, but a very nasty looking crack.
Picture with the crank on Magnaflux MPI crack tester. I bought this crank via e-bay from a professional engine builder advertised as 'reground EN40B 1275S crank in good condition' As the picture shows it wasn't! there was a bigger crack on the other side of the same journal! Luckily I paid for it with my Visa card so was able to get a full refund after waiting about six months, the e-bay dispute system was a waste of time. It did reappear on e-bay with the same photos and discription later but was withdrawn before the auction ended, hopefully no one else bought it.
It did cheer up the crack test guy at work though..........he spends every day looking at hundreds of items looking for tiny cracks and along comes this gem.
Re: Bad Luck
Posted: Thu Nov 25, 2010 8:02 am
Glad you spotted it!
It is the sort of crack that would not look out of place in a crack testing text book!
Re: Bad Luck
Posted: Thu Nov 25, 2010 10:10 pm
by Tim
Does that crank still 'ring' if you hold it up and hit it?
Re: Bad Luck
Posted: Thu Nov 25, 2010 11:33 pm
by Pete
Tim wrote:Does that crank still 'ring' if you hold it up and hit it?
I remember that's the first thing Jeff Goodliffe did to a crank of mine when I handed it over to him, many moons ago.
Re: Bad Luck
Posted: Fri Nov 26, 2010 12:55 am
by Tim
Its meant to be a poor man's crack test. Supposedly it will sound dull if its cracked, but I've heard that its very unreliable so it would be interesting to know how bad a crack needs to be to stop it ringing.
Re: Bad Luck
Posted: Fri Nov 26, 2010 8:21 am
I have had very poor cranks that still ring, I reckon that using a set of divining rods is about as accurate as the "ring test"
For home use something like this;
http://www.pegasusautoracing.com/produc ... RecID=1207
is a far better bet.
Re: Bad Luck
Posted: Fri Nov 26, 2010 6:59 pm
by littler
did you buy it off that rite dodgy 251eng ebay seller geezer?
ive used crack sprays with work on uprights and when we did some precision tiging on a modular crank we built.good stuff.
Re: Bad Luck
Posted: Fri Nov 26, 2010 8:50 pm
by 1071bob
[quote="littler"]did you buy it off that rite dodgy 251eng ebay seller geezer?
No it wasn't 251eng, but they do share the same christian name.
The guy I bought the crank from obviously suffered from amnesia which meant that as soon as he agreed that the crank was cracked and he would refund the money he would forget the conversation when he put the phone down, and after his bank refunded the money he 'forgot' the crank was cracked and tried to sell it to someone else!
Re: Bad Luck
Posted: Fri Nov 26, 2010 8:52 pm
by guru_1071
1071bob wrote: he 'forgot' the crank was cracked and tried to sell it to someone else!
he didnt sell to to a bloke in hong kong did he?
it might be the same crank
Re: Bad Luck
Posted: Sat Nov 27, 2010 6:00 am
by 970s
Rich,
I am sure the crank is not sold to Hong Kong, otherwise I must have seen it!
shipping a crank to Hong kong is expensive, and usually they bought the whole motor !
