Bad Luck
970s
Bad Luck
Post by 970s »
:cry: :cry: :cry:
The driver must have bad luck! :evil:
Lucky the casing can survie with a little welding!
5 gears intact! :oops:
Al
Re: Bad Luck
OUCH!
It looks like the owner had a very lucky escape all things considered.
Does anyone know why short stroke cranks usually go there?
guru_1071
Re: Bad Luck
Post by guru_1071 »
mark, id guess either a poorly balanced flywheel, or poor primary gear clearance - which cooks the oil at that end
my 970 broke at the same place
InimiaD
Re: Bad Luck
Post by InimiaD »
That pic brings back BAD memories. :cry:
I snapped a crank, same place as in the pic and that was a 1275 semi s/stroke.
Saved everything except for a crankshaft, obviously, and a flywheel housing.
251 ENG
Re: Bad Luck
Post by 251 ENG »
That,s the point where all the load is from engine to transmission .
Bet any money it started with a crack in no4 fillet radius .
Also looks quite an old crank design , has it been reground ?
Bad grinding of fillet radius is a sure way to kill a crank .
970s
Re: Bad Luck
Post by 970s »
That is one racing motor built in UK! :roll:
Agressive driver! :mrgreen:
Al
1071bob
Been thanked: 44 times
Re: Bad Luck
Post by 1071bob »
Yep,
Re: Bad Luck
Nice picture, but a very nasty looking crack.
Did you get that done at work Bob?
1071bob
Re: Bad Luck
Post by 1071bob »
mk1 wrote:Nice picture, but a very nasty looking crack.
Picture with the crank on Magnaflux MPI crack tester. I bought this crank via e-bay from a professional engine builder advertised as 'reground EN40B 1275S crank in good condition' As the picture shows it wasn't! there was a bigger crack on the other side of the same journal! Luckily I paid for it with my Visa card so was able to get a full refund after waiting about six months, the e-bay dispute system was a waste of time. It did reappear on e-bay with the same photos and discription later but was withdrawn before the auction ended, hopefully no one else bought it.
It did cheer up the crack test guy at work though..........he spends every day looking at hundreds of items looking for tiny cracks and along comes this gem. :lol:
Re: Bad Luck
Glad you spotted it!
It is the sort of crack that would not look out of place in a crack testing text book!
Tim
Has thanked: 4 times
Been thanked: 19 times
Re: Bad Luck
Post by Tim »
Does that crank still 'ring' if you hold it up and hit it?
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Pete
Has thanked: 46 times
Been thanked: 122 times
Re: Bad Luck
Post by Pete »
Tim wrote:Does that crank still 'ring' if you hold it up and hit it?
I remember that's the first thing Jeff Goodliffe did to a crank of mine when I handed it over to him, many moons ago.
Tim
Re: Bad Luck
Post by Tim »
Its meant to be a poor man's crack test. Supposedly it will sound dull if its cracked, but I've heard that its very unreliable so it would be interesting to know how bad a crack needs to be to stop it ringing.
Tim
1955 BSA C11G
1969 Triumph TR6R
Re: Bad Luck
I have had very poor cranks that still ring, I reckon that using a set of divining rods is about as accurate as the "ring test"
For home use something like this;
http://www.pegasusautoracing.com/produc ... RecID=1207
is a far better bet.
littler
Re: Bad Luck
Post by littler »
did you buy it off that rite dodgy 251eng ebay seller geezer? :P
ive used crack sprays with work on uprights and when we did some precision tiging on a modular crank we built.good stuff.
1071bob
Re: Bad Luck
Post by 1071bob »
[quote="littler"]did you buy it off that rite dodgy 251eng ebay seller geezer? :P
No it wasn't 251eng, but they do share the same christian name. ;) The guy I bought the crank from obviously suffered from amnesia which meant that as soon as he agreed that the crank was cracked and he would refund the money he would forget the conversation when he put the phone down, and after his bank refunded the money he 'forgot' the crank was cracked and tried to sell it to someone else! :roll: :lol:
guru_1071
Re: Bad Luck
Post by guru_1071 »
1071bob wrote: he 'forgot' the crank was cracked and tried to sell it to someone else! :roll: :lol:
he didnt sell to to a bloke in hong kong did he?
it might be the same crank ;)
970s
Re: Bad Luck
Post by 970s »
:? :roll: :roll:
Rich,
I am sure the crank is not sold to Hong Kong, otherwise I must have seen it!
shipping a crank to Hong kong is expensive, and usually they bought the whole motor !
:mrgreen:
Al
