Weight of Engine and Box.
nick rogers
Post by nick rogers »
Can anyone give me an idea of the weight of a built up 1275 with all ancillaries ? I am shipping 10 and need to comply with regs for trailers.
Thanks.
InimiaD
Re: Weight of Engine and Box.
Post by InimiaD »
I'm sure I read somewhere that it was about 150 KGs.
Can someone more learned than this old duffer confirm.?
Dr S
Post by Dr S »
That's the number that came into my mind
nick rogers
Sounds about right, thanks folks. Anyone got any more precise suggestion?
timmy201
Been thanked: 42 times
Post by timmy201 »
This is pretty precise, you'll need to get your calculator out though!
http://www.theminiforum.co.uk/forums/to ... 4-weights/
Has thanked: 206 times
Been thanked: 79 times
The Marchall Brothers quote 350 lbs
goff
Post by goff »
Nick if you look in the service manual , the one I have is only for mk1 , it says engine transmission assembly 333lb or 151kg , auto says 357 lbs or 162 kg
Hope this helps, see you at Blyton .
Goff
nick rogers
Thanks everyone. I will work on 155kg to be on the safe side.
