Flywheel taper woe's
Chalkie
Post by Chalkie »
Morning guys
Sorry to be a Pain again.
Brought a Flywheel ages ago now come round to having my rotating assembly balanced the engineer said I need to clean the taper on the flywheel up but I have done this before and done it again this morning but it still looks crap to me is this fly wheel scrap?
thanks
Steve
rich@minispares.com
Re: Flywheel taper woe's
Post by rich@minispares.com »
grinding paste and some furious lapping should sort that out
as long as both surfaces can be made to go a uniform flat grey colour you are sorted
the one on my race car was a LOT worse than that last time it came off!!!
It certainly doesn't look great. However, all is not lost.
It looks like you have a couple of serious high spots. Get these removed first, using a die grinder or similar "Dremmel" type tool. Once these serious high spots are clear, lap the flywheel onto the crank using first coarse grinding paste then fine grinding paste & if you are feeling particularly conscientious then with Brasso (I never bother with this last stage.
As long as there aren't any serious high spots left & the VAST majority of the remaining surface has taken some "grind" you should be OK.
The mistake you made was buying a second hand flywheel. People only sell them when they think they are knackered.
Chalkie
Post by Chalkie »
I may just buy a New one to be fair
I have given it ago at cleaning it up just worried ill ruin the taper
