Changing diff ratio without splitting engine/box
Posted: Thu Feb 19, 2015 6:57 am
by AndyB72
Is there a way of locking the gearbox to change the diff ratio without splitting the engine/gearbox?
Re: Changing diff ratio without splitting engine/box
Posted: Thu Feb 19, 2015 7:09 am
Gosh yes, why make work when you don't need to!
Remove the diff outputs (flanges, yokes or pot joints), remove the diff side plates, remove the diff cap and there's the Crown Wheel, change that over.
Remove the Speedo Drive End Housing, lock in 1st and 4th (all synchro) or 2nd and 4th (3 Synchro) depending on the type of gearbox, undo Pinion nut, remove Pinion, refit, and basically the reverse of the above.
Regasket, reseal, re-shim the diff, all on a sasame seed bun
Posted: Thu Feb 19, 2015 9:16 am
by rich@minispares.com
you can do it but its an utter git to lock a rod change into 1st and 4th, its easy on a remote as the fork rods are accessible (but take the two detent plunger cover bolts out first to make it easier to manipulate the forks)
Posted: Thu Feb 19, 2015 9:51 am
rich@minispares.com wrote:you can do it but its an utter git to lock a rod change into 1st and 4th
Mmmm,,, rubbish. It's easy enough, though fair enough, it's easier on a remote box.
Posted: Thu Feb 19, 2015 10:47 am
by AndyB72
Smart thanks! Its a remote box by the way.
Posted: Thu Feb 19, 2015 10:49 am
Spider wrote:rich@minispares.com wrote:you can do it but its an utter git to lock a rod change into 1st and 4th
not if you have massive hands like me it isnt
I have a bent screwdriver for hooking/pushing the 3rd/4th hub across, which does help!
Posted: Thu Feb 19, 2015 11:43 am
Posted: Thu Feb 19, 2015 6:59 pm
Yeah, that's pretty much how I do them, on the shift bell crank
Push the 3rd / 4th crank IN, then lever the 1st / 2nd hub across, sometime need to rock the gears a little to get that one on.
But, that's all academic, as the OP has a remote.
and Mark
mk1 wrote:
I recon my fingers are at least as big as this guys
