I just finished the (5 year) restoration of my '66 cooper (will post a topic soon). It sailed through its MOT
The shiny one is the new cylinder. It's considerably longer.
I'm thinking of buying a new tin type clutch master cylinder, just to be sure, but is that a straight swap? I've read things about different rod lenghts causing problems?
Another option is using a master cylinder body i have had lying here. I think it's a brake master cylinder, but it's also a 0.75" bore.
Are the brake and clutch master cylinders internally the same?
I know they are differently angeled, I tried it on and it looks a bit odd, but could work for now...
So, any advice appreciated: did i fit the repair kit OK? Is the cylinder too long? should I stop hassling and buy a new one?
