Mk1 Door repair, rain channel
austinseven7
Post by austinseven7 »
Hi,
Would anyone know if you can buy a replacement horizontal channel that sits under the chrome sliding window trim.
It looks like part of the door structure, but wonder if anyone has reproduced this part as a repair panel. Has holes that drains water into a channel then leads water out the end of the door.
Austin Seven early 1960. Cheers
Dr S
Re: Mk1 Door repair, rain channel
Post by Dr S »
Yes you can, m machine do them, think they are about a tenner.
dklawson
Post by dklawson »
My car is later with the tubes that drain via the vertical tubes that exit the bottom of the door. I didn't want to completely replace the ones in my car's doors since the rust perforations were not too terrible. Instead I sandblasted, acid washed, and applied epoxy filler followed by POR-15. That sealed all the holes and seems to be holding up well after a decade. However, my car only sees rain and water a few times a year.
Doug L.
