Window channels/runners
davidmuir
Has thanked: 18 times
Post by davidmuir »
Folks,
Just replaced the window channels/runners and now the window catches 'don't want to' locate in the locking holes! (windows slide nice and freely).
Anyone had this 'problem'?..........what's the answer?
Ta
Re: Window channels/runners
This is fairly common.
Try slackening the bolts for the window catch off a bit, they should now manage to locate in the holes, re tighten with locks located in the holes. Job done.
LarryLebel
Post by LarryLebel »
Ovalize the holes.
nippycars
Post by nippycars »
don't buy stainless channels have the original rechromed.
Website now LIve, www.nippycarsonline.com
Pete
Has thanked: 59 times
Been thanked: 148 times
Post by Pete »
As above plus if you've not sealed and screwed it all in already it'd be worth checking whether the top channel is not a little too thick.
davidmuir
Post by davidmuir »
Thanks folks. Will try all of the answers (one of the original chromes was goosed!). Will persevere with the stainless!
nippycars
Post by nippycars »
Instead of sitting on the fence i am going to stick up for the restorers of these cars that are trying to make a livelihood,
You could buy a stainless window runner for £20 and some repro window catches for £25ish per side and guess what they Won't work
OR
you can spend hours trawling the net or shows, find some originals that need rechroming for say £10-15 spend an hour or more taking them to the chromers (another £20 for chrome) and also have to collect them back, then try and find some original catches that just need a clean up and hey presto you have the same set up as above but its cost 2-3-4 times the ammount, BUT it works properly.
STG95F
Post by STG95F »
Work and look correct
