Ideas for a front number plate hanger
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Hi, Having bought some B&W raised digit plates and thinking I will pop them on as a ten minute job as ever there is an obstacle. The raised digits align perfectly where I need to drill my beautifully centred new number plates ie where you fix them to the front panel brackets. As a solution I thought I would add a number plate backing panel but the front number plate hanger I have has a raised edge. This will clash with my bevel/raised edge raised digit number plates so i cant screw it down without pulling the b'strd thing in. Pah!
Anybody know of somewhere that sells a flat backing plate. Happy to get one made but a lot of fannying around by the time i cut, dril and paint it and I TBH would prefer to get one off the shelf. Do any other cars have something similar if not.
morris cooper
Re: Ideas for a front number plate hanger
Post by morris cooper »
Just put a spacer or some washers between your new plate and the backing plate to avoid crushing the number plate,
Bill
rolesyboy
Post by rolesyboy »
Thanks Bill. Have considered that but really looking for something a bit more substantial ie a ready finished flat plate
swifty
Been thanked: 38 times
Post by swifty »
Mark . I've just fitted them to the green mini and I've mixed some plastic padding and bonded them on . Looks a treat with no screw holes . . Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
lwarrine
Post by lwarrine »
Could you not just use a piece of stainless steel sheet .... If it's slightly smaller than the plate you won't really see it & no corrosion problems .....just cut down to the correct size & holes drilled / punched as required.
Depending on the size etc. I might be able to knock something up if you get stuck as have access to some stainless offcuts and a few machines.
