The engine was out of an autograsser who had used it in 3 races and then stuck it in his shed. I bought it for the princely sum of £570 (a few years ago). It was a Bill Richards job originally and then recently rebuilt by Baldwin. It was running 137 baldwins at the flywheel.
The "silly" camshaft was the subject of a previous thread.
The "lump" consists of 84mm "normal" crank, S rods, omega 7cc pistons (73.5), 1:1 SC drops, 4 syncro SC box 3.6FD and salisbury diff. It was breathing through a pretty good head pictured below. 26cc chambers 37/31 valves and BIIIIG inlet ports. Ex ports seem quite small. S Rockers and likely to be a full full full race cam (matey said it was as crazy as they came....unknown). Weber 48 on a 7" manifold with 60mm trumpets. Not sure of the jets or the chokes, but they were "right".
The mini is a 66 running dry suspension...all played with properly. The car has no carpets, roll cage and is not designed for driving to work in....although I used to. It's basically a road going go kart. I don't care how expensive it is to run, how noisy it is, or what it smells like.
It will be having a moderately sensible clutch put in it, although it does have a seriously worked steel flywheel. I might replace this for a really light one, in the interests of accelleration.
I was just going to rebuild it as it is, but was reading about engines on the interweb and someone mentioned something about a high winding 1430 needing regular rebuilds. That made me go "WHOA" and ask the experts.
I accept that my engine is going to require regular love, but it's my prerogative to put it together properly and use the right lubricants to ensure that it doesn't "blow up".
I was going to ditch the Weber DCOE as I haven't got the heart to go chopping the dash around and moving the speedo and go for an IDA. This is still an option. The IDA vs SU debate will be one to have. I'd like to retain exciting performance, whilst not having to rebuild it every 1000 miles.
I'm aiming to keep the head, probably keep the S Rockers. I figure that whopper ports and valves are going to have everything moving anyway. I will hold the "getting a 3>1 manifold" for a minute.
I'm at the moment putting the diff back on the box....damn, need some diff bolts. Then it will be onto cleaning everything and assembling it. I don't want to be too hasty.
I quite like the idea of having something which is an absolute handful to drive, but does not require a rebuild every year. Car will get used "occasionally".
Using that head/rocker/engine/gears setup, what cam would make the best out of it, with a sensible rev limit that a "normal" 1430 bottom end can take without causing major wear?
Before anyone says "It's not green". 99% of the paint was taken off with solvents.....the green
