1971 Early MK3 850
Jebo
1971 Early MK3 850
Post by Jebo »
Hi,
I am Jeroen and live in The Netherlands. Since two years I am the owner of an early 850 mk3 and have just started the Restoration process.
Some background:
I am the second owner of this very original Dutch Mini. The Mini was originally won by its owner by a pigeon competition in 1971 and has stayed with this owner until 1989 when it was put into storage. Within all those years only 41.000 kilometres was put on this car and nothing has been changed.
My plan is to restore it completely like it was in 1971, but with some period upgrades. I already have an original Speedwel rev counter and accelartor pedal, Springalex steering wheel and 5x10 GB alloys from the first series.
Suspension will be the usual adjustarides, adjustable camber/caster and Spax dampers.
For the engine I am still uncertain and I am doubting about a lightly tuned 998 or 1098 in combination with 4 sync magic wand.
For safety reasons I will add seatbelts in the back and ugrade the brakes to disc brakes.
Currently the bodyshell is under Restoration with a local specialist (http://www.7heaven.nl/) and the plan is to build it up again over winter.
If you have any suggestions or questions, please let me know!
1970 - MK3 850 - viewtopic.php?f=6&t=10563
minidean
Re: 1971 Early MK3 850
Post by minidean »
Hi Jebo,
Any pictures????
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
Hoi Jeroen.
Top ik ben erg benieuwd naar het resultaat ;) ( dutch )
Kees
Jebo
Post by Jebo »
Some pictures before we started!
Jebo
Post by Jebo »
Ready for "Thermal paint stripping":
Back from the "oven":
After a mild sandblast and welding primer:
I'll update with welding progress soon!
JC T ONE
Post by JC T ONE »
Hi & welcome :)
Nice car, with nice history 8-) but if it had been mine (which it aint) I would have kept it original.
Early MK III,s in original spec are not easy to find, and rearly turn up at shows anymore :(
Atleast think about it.
Jebo
Post by Jebo »
Thanks JC T One for your reply!
I'll keep the outside looking original except it will be a bit lower and have alloys (period correct GB's) On the inside I will have some period correct changes, but not too much!
The goal is to have an original appeal, but with some performance upgrades. Ofcourse I will keep all original parts to revert to standard easily.
The bodyshell needs to be repaired in the way it came from the factory and most parts will be Nos or good replica's to be replaced over time.
Jebo
Post by Jebo »
New floors and sills:
Right side of the car:
`Ready:
Jebo
Post by Jebo »
Rear floor repair:
Some upgrades (not for the purists...):
Boat board and sparewheel clamb:
Rearshelf repair:
Rear seatbelt upgrade:
Now waiting for new panels for the front and doors!
JC T ONE
Post by JC T ONE »
Pwoar - that welding porn for yea 8-)
Nice work 8-)
Did it already have boot board brackets on the rear bulk head :?:
JC T ONE
Post by JC T ONE »
Jebo wrote:Thanks JC T One for your reply!
Good plan 8-)
SUPERB WORK!
Jebo
Post by Jebo »
Thank you for all the positive replies!!! Looking forward already to the end result! :D
Jebo
Post by Jebo »
Some questions for the experts!
How can I find out the exact build date? British Motor Industry Heritage states they only have record for minis built between 1959-1969 and 1977-1981.
Moreover where was this car build, some say Seneffe (Belgium) due to the larger indicator lights?
I believe the differences to see if it is an early mk3 850 are the following or are there more? :roll:
Mk2 boothandle:
Magic wand:
Iginition key in the center and plastic heaterbox:
Thicker chrome opening rear windows:
Jebo
Post by Jebo »
Can anyone help me to identify to the build date of my Mini like stated in my previous post?
nick@dunsdale
Has thanked: 9 times
Post by nick@dunsdale »
Yep I had an 850 with centre key start and wand gearstick.
Also pretty sure you car is different spec to uk 850's as the mk3 850's had fixed non opening quarter glass. Also only had a centre speedo, no fuel or temp gauges.
Unlike the 1000's witch had both the above.
JC T ONE
Post by JC T ONE »
The 850 kept the magic want upto October 72, when the whole Mini range got the rod change system.
The bigger front indicators were also used on the MK III Cooper S cars, that were sold here in Denmark.
Check to see if your car have the MK II interior light ?
Did you save the body no from your front panel ?
Craig
Post by Craig »
Nice to see a proper job being done !!! Spot welding porn for sure !!!!!
Bet it will be nice when finished. :D
Those front signal lights where also used for the Canadian market cars .
Craig
Jebo
Post by Jebo »
thanks for the replies!
Yes I have the mk2 interiorlight and the bodynumber is : 228609
Looking forward to an indication of the build date!
Was it build in Sneffe Belgium?
Jebo
Post by Jebo »
And some further progress:
Nose:
