Lucas SFT576
Posted: Mon Sep 22, 2014 7:47 pm
by swifty
Hi . Going to be fitting 4x Lucas SFT 576 spots and fogs to my on going project . It's not a rally project or anything just road car . Is it ok to just wire these into the main beam loom . I will be fitting a alternator . .... Ken
Re: Lucas SFT576
Posted: Mon Sep 22, 2014 8:41 pm
by captain
you will have to wire them through a relay or you will burn your switch out,fire hazard
Re: Lucas SFT576
Posted: Mon Sep 22, 2014 10:12 pm
by LarryLebel
I had LR6s wired via a relay into my high beams. My lights have covers so whenever I needed the high beams I would have to take the covers off which was a PITA. I rewired the spots on a dedicated switch.
Re: Lucas SFT576
Posted: Tue Sep 23, 2014 12:53 am
by Tim
Out here its a legal requirement that spots must have a seperate switch and dip (turn off) when the high beam dips, so their relay is energised by the high beams, but only when switched on.
Re: Lucas SFT576
Posted: Tue Sep 23, 2014 1:15 am
by JC T ONE
Tim wrote:Out here its a legal requirement that spots must have a seperate switch and dip (turn off) when the high beam dips, so their relay is energised by the high beams, but only when switched on.
Same here in Denmark, and fog lights can only work with either side/ lights or low beam, they must turn off when high beam is on.
Re: Lucas SFT576
Posted: Tue Sep 23, 2014 3:57 pm
by Ronnie
If your lights were below 24" centre hight in the UK it used to be (and I believe still the case) they can only be used in fog or falling snow there are also limitations on the distance between lighted surfaces, which used to be pointed out when you purchased a ST lamp bar. If your lights are above 24" you can use on the road but they must only be used with main beam and extinguish when you dip your headlights.
On a forrest road you can switch them all on.
Re: Lucas SFT576
Posted: Tue Sep 23, 2014 4:06 pm
by rich@minispares.com
what ever combination you use, a relay is a must
the switches and stalks get mighty hot if you don't!
Re: Lucas SFT576
Posted: Tue Sep 23, 2014 4:25 pm
by swifty
Thanks everyone . ...ken
