Macker2
Posts: 156 Joined: Thu Oct 11, 2012 8:20 pm
Post
by Macker2 » Mon Sep 08, 2014 1:12 pm
The acid dip ate my engine number plate , there are only the rivets left.
Sounds a bit shady but is it possible to get a replacement one pressed.
Macker
Macker2
Post
by Macker2 » Mon Sep 08, 2014 2:54 pm
Thanks Rich, I will give him a ring
woodypup59
Posts: 1574 Joined: Thu Jun 24, 2010 5:28 pm
Has thanked: 8 times
Been thanked: 23 times
Post
by woodypup59 » Mon Sep 08, 2014 6:54 pm
Also beware that the acid will eat away any brass oilway plugs.
Don't ask how I know !
Macker2
Post
by Macker2 » Mon Sep 08, 2014 7:24 pm
I have taken them all out woody
I will need to replace the single cam liner though. Doesn't seem to be available any more, I wonder if one of the set of 3 for a later model will fit. ?
Posts: 4860 Joined: Mon May 07, 2012 6:10 am
Has thanked: 204 times
Been thanked: 78 times
Post
by Spider » Mon Sep 08, 2014 9:01 pm
Macker2 wrote: I have taken them all out woody
I'm pretty sure the front one from the set is the same.
carbon
Posts: 518 Joined: Fri Jan 07, 2011 8:26 pm
Post
by carbon » Mon Sep 08, 2014 9:15 pm
Look on the bright side - at least you should be able to take the two rivets out now without too much bother.
When the engine plate is in place it is really difficult to get the rivets out without trashing the plate...
Macker2
Post
by Macker2 » Mon Sep 08, 2014 9:36 pm
Cheers spider I was hoping that was the case.
Haha I suppose you have a point there carbon
