Removing LCB tip
IslandBlue
Removing LCB tip
Post by IslandBlue »
This has always been a job that I have looked forward to with some trepidation as many years of hammering away at the y-piece to separate the downpipes has left me mentally if not physically scarred.
First thing to say is that it always helps to have a willing accomplice to tug and wriggle the exhaust from the rear of the car once the joint begins to budge.
Whilst the clamp at the rear of the y-piece is a handy point for your accomplice to clout the exhaust section backwards it helps if you can simultaneously strike the downpipe in the opposite direction to maximise the chance of separation of the joint. This time I hit upon the idea of attaching an old exhaust clamp around one of the downpipes forward of the joint giving a handy point to clout the downpipe forwards - worked a treat.
graham.codling
Re: Removing LCB tip
Post by graham.codling »
I. Don't use clamps on y piece to manifold .weld one small bracket to manifold and one to y piece either use large split pin or spring to secure small amount of ex paste find it easy to get of without damage to y piece or manifold
