C-AHT1 bracket
dgear1984
C-AHT1 bracket
Post by dgear1984 »
As you may be aware I am building a set of h4 carbs for my 1725s engine.
I have got a choke cable bracket (abf 226) from SU which is does the same job as the ST c-aht1 although does look different.
Does anyone have any detailed measurements of the semi circular c-aht1 bracket so I can make a decent copy for the car. The SU one although will perform fine, just looks a little bit heavy duty...
Thanks Dave
Re: C-AHT1 bracket
nOW AVAILABLE FROM BURLEN FUEL SYSTEMS.
nOT ON THE WEB SITE, BUT IF YOU PHONE UP THEY CAN HELP. aLSO APPLIES TO c-aht 2
Re: C-AHT1 bracket
^ CapS lOck MalfunctioN? 8-)
Re: C-AHT1 bracket
Whoops!
dgear1984
Re: C-AHT1 bracket
Post by dgear1984 »
Hi,
The one they sell is a thick plate version. I was looking for the semi circular pressed one.
I have made on now, took a while but.......
